Ring Stick Up Cam Battery Battery Replacement
  1. Ring Stick Up Cam Battery Battery Replacement, Battery: step 1, image 1 of 1
    • Turn the camera so the lens is facing away from you, and the back is facing towards you.
    • Place one hand securely on the base and the other on the stand.
    • Carefully twist your bottom hand counterclockwise until the indicator line reaches the unlock icon.
    Ask FixBot
  2. Ring Stick Up Cam Battery Battery Replacement: step 2, image 1 of 1
    • Gently pull down to separate the stand from the camera body.
    Ask FixBot
  3. Ring Stick Up Cam Battery Battery Replacement: step 3, image 1 of 2 Ring Stick Up Cam Battery Battery Replacement: step 3, image 2 of 2
    • Hold the camera so the opening containing the battery is toward the ceiling.
    • Squeeze the silver lever labeled "push" and extract the battery from its slot.
    Ask FixBot
Caroline Smith
267 Reputation
2 Guides authored
Marist, Team 1-1, Chaterdon Spring 2023 Member of Marist, Team 1-1, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G1
3 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 25
Past 30 Days: 200
All Time: 2,141
