Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background:
Released in April of 2024, the RetroMini Miyoo Mini Plus is a handheld video game emulator that takes design inspiration from the Nintendo Gameboy Family of systems. This device plays games on its hardware via Rom Files, allowing for the playing of retro games on the go.
The RetroMini Miyoo Mini Plus weighs at 165 grams, being 3.07 x 4.25 x 0.8 in dimensions. The Device itself comes in a variety of colors, with options of a clear and opaque shell. Within the shell itself is housed a 3.5" IPS display, with a resolution of 680x480. The device itself comes with a Type-C 5V charger to allow for the ability to play for 4-6 hours in a charge.
Less than a year after its release, problems have been reported regarding malfuntioning screens and power buttons. However, this issue was not prevalent enough to issue a recall on the device. Despite these setbacks, most people have have praise for the RetroMini Miyoo Mini Plus.
RetroMini is advertising the Miyoo Mini Plus on their site alongside their other flagship systems, the RG35XXSP, R36s, and Miyoo A30.
Identification:
The RetroMini Miyoo Mini Plus feels very solid when you try to lift the device. It is in the form of a brick shape with 15 buttons with four of them being in the back of the RetroMini Miyoo Mini Plus. It has a 3.5" screen situated above the buttons, A, B, X, and Y, along with a D-pad. There are also two more buttons on the bottom of the device which are "SELECT" and "START". There are four buttons on the back, those being "L" and "L2" alongside "R" and "R2". The RetroMini Miyoo Mini Plus requires a USB-C charging cable (for, as one might guess, charging) and can come in various designs.
Technical Specifications:
The RetroMini Miyoo Mini Plus includes the following:
  • CPU: ARM Cortex A7 Dual Core CPU 1.2 GHz
  • RAM: DDR3 128MB
  • Storage: up to 512GB
  • System: Linux OS/Onion OS
  • Screen: 3.5″ IPS @ 640x480 Resolution
  • Battery: Built-in battery Li-Po 3.7V 3000mAh
  • Playing Time‎: 5-6 hours
  • Dimensions: (HxWxD): 108 mm X78.5 mm X 22.3 mm
  • Weight: 165 g
Follow this Troubleshooting Page to troubleshoot common issues.
Order the RetroMini Miyoo Mini Plus Here
Miyoo Mini (and Miyoo Mini Plus) Starter Guide – Retro Game Corps
Author
with
Kaden
599 Reputation
4 Guides authored
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 126
All Time: 2,352
