Up to 20% off select tools
Medical Equipment
Neither iFixit nor this repair information is endorsed by or affiliated with the medical device manufacturer.
Guides
Documents
Visual List of parts:
Background and Identification
The Puritan Bennett™ 980 Ventilator Series uses innovative technology in order to help patients breathe more easily. The device features an intuitive and customizable user interface display, a unique safety system to ensure continuous ventilation support, an integrated expiratory filtration system, and Synchronization tools to help medical professionals set up the device.
This devices’ unique safety system ensures that continuous ventilation support remains as close to the required settings as possible in the event of certain system failures.
The synchronization tools help medical professionals set up the device to best suit their patients’ unique needs and help to provide a sufficient level of support for the patient’s breathing.
Specifications
Dimensions
  • Height: 148 cm
  • Width: 32 cm
  • Depth: 30 cm
  • Weight : 51.26 kg
Display Screen
  • Size: 38.1 cm
  • Rotation: 170 degrees
  • Tilt: Up to 45 degrees from vertical
Pneumatic Specifications
  • Oxygen and Air Inlet Supplies:
    • Pressure: 241 to 600 kPa (35 psi to 87 psi)
    • Flow: Maximum of 200 L/min
  • Gas Mixing System: Up to 80 L/min for pediatric circuit type Up to 150 L/min for adult patients. Additional flow is available (peak flow to 200 L/min) for compliance compensation.
  • Maximum Limited Pressure (PLIM max): Limits circuit pressure to < 125 cmH2O (123 hPa) at the patient wye.
  • Maximum Working Pressure (PW max): PW max is ensured by the high-pressure limit when PI is 90 cmH2O (88.26 hPa).
Measuring Devices
  • Pressure Measurements:
    • Type: Solid-state differential pressure transducer
    • Sensing Position: Inspiratory module, expiratory module
  • Flow and Volume Measurements:
    • Type: Hot film anemometer
    • Type: Proximal flow sensor option utilizes differential pressure
    • Sensing Position: Patient wye
  • Oxygen Measurement:
    • Type: Galvanic cell
  • Oxygen Sensor Life: Up to one year; operating life varies depending on oxygen usage and ambient temperature
Filtration Capabilities
  • Internal inspiratory filter bacterial/viral filtration efficiency: > 99.999%
  • Internal inspiratory filter particle filtration efficiency: > 99.97% retention of particles 0.3 μm nominal at 100 L/min flow
  • Exhalation filter resistance (adult/pediatric, disposable): < 0.7 cmH2O at 30 L/min (new) < 0.35 cmH2O at 15 L/min
  • Expiratory filter bacterial/viral filtration efficiency: > 99.999%
  • Exhalation filter particle filtration efficiency, pediatric/adult, disposable: Maximum of 0.03% penetration of particles 0.3 μm nominal at 30 L/min flow
Circuit Compliance and Resistance
  • Circuit Compliance:
    • Pediatric: 1.05 mL/cmH2O to 9 mL/cmH2O
    • Adult: 1.05 mL/cmH2O to 12 mL/cmH2O
  • Inspiratory Limb Circuit Resistance:
    • Pediatric: 0.2 cmH2O/L/s to 7.5 cmH2O/L/s at 30 L/min
    • Adult: 0.2 cmH2O/L/s to 12.5 cmH2O/L/s at 60 L/min
  • Expiratory Limb Circuit Resistance:
    • Pediatric: 0.2 cmH2O to 7.5 cmH2O at 30 L/min
    • Adult: 0.2 cmH2O to 12.5 cmH2O at 60 L/min
Electrical Specifications
  • Electrical Ratings Without Compressor:
    • 100 V ~, 50–60 Hz, 2.25 A
    • 120 V ~, 50–60 Hz 1.5 A
    • 220–240 V ~, 50–60 Hz, 0.75 A
  • Mains Overcurrent Release:
    • CB1: 4 A ''
    • CB2: 6 A
  • Earth Leakage Current: 300 mA
  • Touch Current: 100 mA
  • Patient Leakage Current: 100 mA maximum
  • Electrical Ratings with DC Compressor:
    • 100 V~, 50–60 Hz, 8.25 A
    • 120 V~, 50–60 Hz, 6.0 A
    • 220–240 V~, 50–60 Hz, 3.0 A
Environmental Specifications
  • Temperature:
    • Operation: 10°C to 40°C (50°F to 104°F)
    • Storage: -20°C to 70°C (-68°F to 158°F)
  • Atmospheric Pressure:
    • Operation: 70 kPa to 106 kPa (10.15 psi to 15.37 psi)
    • Storage: 50 kPa to 106 kPa (7.25 psi to 15.37 psi)
  • Altitude:
    • Operation: -411.5 m to 3048 m (-1,350 ft to 10,000 ft)
    • Storage: 6,096 m max (20,000 ft max)
  • Relative Humidity:
    • Operation: 10% to 95% non-condensing
    • Storage: 10% to 95% non-condensing
Troubleshooting
For additional help on the Puritan Bennett 980 Ventilator, check out the device's troubleshooting page.
Recall
Note: This unit was recalled. Update Software on your unit.
http://www.globenewswire.com/news-releas...
https://www.accessdata.fda.gov/scripts/c...
Additional Information
* Manufacturer's Home page on Puritan Bennett 980 Ventilator
Puritan Bennett Ventilateur seÃÅrie 980
Puritan Bennett Respirador serie 980
Puritan Bennett 980 Ventilator Capnography Addendum
Puritan Bennett 980 Series Ventilator
Author
with
Arthur Shi
354,431 Reputation
938 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 1
Past 7 Days: 26
Past 30 Days: 102
All Time: 7,939
