Battery
1 Answer 2 Score |
Listed replacement battery mAh does not match. |
2 Answers 0 Score |
Why does the sound pause when I switch between apps? |
1 Answer 0 Score |
Battery cable does not match with the board |
1 Answer 0 Score |
What power IC does the OnePlus 9 pro use? And where to get one? |
Documents
Models
LE2120 (China), LE2121 (India), LE2123 (EU), LE2125 (Global) , LE2127 (US T-Mobile)
Background
The OnePlus 9 Pro released in Asia and Europe on March 31st, 2021, and released in North America two days later, on April 2nd, 2021. It was priced at $969 for the 12 GB model and $1069 for the 256 GB model. Released as a competitor to the iPhone 12, the OnePlus 9 Pro had more camera capabilities, a better battery, and a USB-C port when competitors were still using lightning connectors to charge. The OnePlus 9 Pro was available from mobile carriers like T-Mobile, Version, AT&T and was produced until March 31st of the next year, eventually replaced by the OnePlus 9 Pro. The OnePlus 9 Pro was made to be an everyday phone with internet, photo, and communication capabilities. It was created by OnePlus Technology, which is owned by its parent company, BBK electronics in China.
The OnePlus 9 Pro has a 120 Hz screen with a 3216x1440 display. The rear facing cameras are an ultra-wide camera with 50-megapixel and a 14 mm lens, a 48-megapixel wide lens, and a 2-megapixel monochrome lens. Video recordings are 8K videos at 30 frames-per-second.
The OnePlus 9 Pro did not have any official recalls, but did have software issues that were addressed and fixed through software updates. Users liked the OnePlus 9 Pro for its performance, camera, and display; however, the phone was considered to be unreliable due to battery and software issues. The OnePlus 9 Pro made 300 million Yen in China (47 million US dollars) during the first 10 seconds of its launch.
Identification
The OnePlus 9 Pro is a smartphone device that contains a screen encased in glass on the front side of the device and on the rear glass panel. There is a raised camera bump with 4 cameras, a flash module, and a microphone. There is a USB-C charging port, sim card tray, loudspeaker, and microphone on the bottom edge of the device. The power button and the alert slider are on the right edge of the device if looking at the screen. The left edge contains the volume buttons. On the top of the device, there is a microphone. On the top of the screen, there is an earpiece speaker at the top of the screen that doubles as a second loudspeaker when playing content on the device. The OnePlus 9 pro is 163.2mm X 73.mm X 8.7mm, weighing 197 grams and comes in two colors: pine green and morning mist.
Technical Specifications
CPU: Qualcomm® Snapdragon™ 888
GPU: Qualcomm® Adreno™ 660
RAM: 8/12GB LPDDR5
Storage: 128GB/256GB UFS 3.1
Display:
- Size: 6.7 inches
- Resolution: 3216*1440, 525 ppi
- Type: LTPO AMOLED
- Refresh Rate: 1-120 Hz (variable)
- Protection: Corning® Gorilla® Glass Victus 2
- Brightness: 1600 nit HBM, 4500 nit peak brightness
Battery: Non-removable LiPo 4,400 mAh (Dual-cell 2,200 mAh)
OS: Android 11 with OxygenOS 11
Camera:
- Rear Cameras
- 48 Megapixel Main Camera (Sony IMX789 sensor)
- 8 Megapixel Telephoto (Unknown sensor)
- 50 Megapixel Ultra-wide Angle (Sony IMX766 sensor)
- 2 Megapixel Monochrome camera (Unknown sensor)
- 720p/1080p at 30/60 FPS or 4K at 30/60/120 FPS or 8K video at 30 FPS
- Dolby Vision® HDR
- Front Camera
- 16 Megapixel (IMX471 sensor)
- 720p/1080p/4K video at 30 FPS
Connectivity
- Wi-Fi: Wi-Fi 2x2 MIMO, Wi-Fi 802.11a/b/g/n/ac/ax
- 5G: n1, n2, n3, n5, n7, n8, n25, n28, n38, n40, n41, n48, n66, n71, n77, n78, n258, n260, n261 (USA variant)
- Bluetooth: Bluetooth 5.2
- Codecs supported: aptX HD, aptX, LDAC, LHDC, AAC, SBC
- NFC: NFC enabled
- Ports:
- USB Type-C
- USB 3.2 Gen 1, USB Host (OTG), DisplayPort Alt Mode (Video out)
- Single nano-SIM slot
- USB Type-C
- Charging:
- Wired charging: 65W SuperVOOC (formerly WARP Charge) ultra-fast charging
- Wireless charging: 50W AirVOOC ultra-fast charging
- Wireless reverse charging: 5W reverse charging
Sensors
- In-display Fingerprint Sensor
- Accelerometer
- Electronic Compass
- Gyroscope
- Ambient Light Sensor
- Proximity Sensor
- Sensor Core
- Flick-detect Sensor
- Front RGB sensor
- Barometer
Dimensions
- Size: 163.2×73.6×8.7 mm
- Mass: 197g
