Up to 20% off select tools
OnePlus 9 Pro Charging Port Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
7
Past 7 Days:
38
Past 30 Days:
226
All Time:
2,512
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 35 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Is your charging port broken/malfunctioning, is the wireless charging not functioning correctly, then this guide is for you. This guide helps you step by step take your OnePlus 9 Pro apart and change out your charging port/wireless charging cable.
    1. OnePlus 9 Pro Charging Port Replacement, Rear Glass: step 1, image 1 of 1
      • For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
      • Unplug any chargers/peripheries and power off your phone.
      Ask FixBot
    2. OnePlus 9 Pro Charging Port Replacement: step 2, image 1 of 1
      Ask FixBot
    3. OnePlus 9 Pro Charging Port Replacement: step 3, image 1 of 2 OnePlus 9 Pro Charging Port Replacement: step 3, image 2 of 2
      • Use a hair dryer to lightly heat the perimeter of the rear glass.
      • Additionally, heat the top-right corner, as there is adhesive further inside of phone in that one spot.
      • Do not hold the hair dryer in one spot on the phone for too long to prevent damage to internal parts of the phone.
      Ask FixBot
    4. OnePlus 9 Pro Charging Port Replacement: step 4, image 1 of 1
      • Apply a suction handle as close to the bottom edge as possible.
      • Pull up on the suction handle with strong, steady force to create a gap between the glass and the frame.
      • If you have trouble creating a gap, apply more heat to further soften the adhesive.
      • Insert an opening pick into the gap.
      Ask FixBot
    5. OnePlus 9 Pro Charging Port Replacement: step 5, image 1 of 1
      • Slide the opening pick around the perimeter of the rear glass to slice the adhesive.
      • Insert additional opening picks as you slice the adhesive to prevent the adhesive from resealing.
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your hair dryer to reheat it.
      Ask FixBot
    6. OnePlus 9 Pro Charging Port Replacement: step 6, image 1 of 2 OnePlus 9 Pro Charging Port Replacement: step 6, image 2 of 2
      • Carefully lift the rear glass up and off of the phone.
      • During reassembly secure the rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
      Ask FixBot
    1. OnePlus 9 Pro Charging Port Replacement, Bottom Loudspeaker: step 7, image 1 of 2 OnePlus 9 Pro Charging Port Replacement, Bottom Loudspeaker: step 7, image 2 of 2
      • Use one of the opening picks to remove the adhesive on the lower part of the wireless charging cable
      Ask FixBot
    2. OnePlus 9 Pro Charging Port Replacement: step 8, image 1 of 3 OnePlus 9 Pro Charging Port Replacement: step 8, image 2 of 3 OnePlus 9 Pro Charging Port Replacement: step 8, image 3 of 3
      • Unplug the press connector ribbon cable attached to the flash module by inserting a spudger under the bottom edge and prying straight up.
      • Use an opening pick to remove the flash module by the camera.
      • Use a Phillips #000 screwdriver to remove the eleven 4.9 mm-long screws holding the motherboard cover to the phone.
      • Use an opening pick to pry off the motherboard cover.
      Ask FixBot
    3. OnePlus 9 Pro Charging Port Replacement: step 9, image 1 of 1
      • Use a Phillips #000 screwdriver to remove five screws that secure the lower daughterboard cover.
      • Two of the screws have a white head and are 4.8 mm-long. They go in the bottom right corner of the daughter and mother board.
      • The other three screws are black and are also 4.8 mm-long.
      Ask FixBot
    4. OnePlus 9 Pro Charging Port Replacement: step 10, image 1 of 2 OnePlus 9 Pro Charging Port Replacement: step 10, image 2 of 2
      • Disconnect the two interconnect cables by inserting a spudger under each lip and prying straight up.
      Ask FixBot
    5. OnePlus 9 Pro Charging Port Replacement: step 11, image 1 of 1
      • Remove the three screws from the loudspeaker using a Phillips #000 screwdriver.
      Ask FixBot
    6. OnePlus 9 Pro Charging Port Replacement: step 12, image 1 of 1
      • Use the spudger to pry up and remove the loudspeaker.
      Ask FixBot
    1. OnePlus 9 Pro Charging Port Replacement, Charging Port: step 13, image 1 of 3 OnePlus 9 Pro Charging Port Replacement, Charging Port: step 13, image 2 of 3 OnePlus 9 Pro Charging Port Replacement, Charging Port: step 13, image 3 of 3
      • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
      • Press firmly to eject the tray.
      • Remove the SIM card tray.
      Ask FixBot
    2. OnePlus 9 Pro Charging Port Replacement: step 14, image 1 of 1
      • Insert a spudger under the lip of the charging port press connector and pry it straight up to disconnect it.
      Ask FixBot
    3. OnePlus 9 Pro Charging Port Replacement: step 15, image 1 of 3 OnePlus 9 Pro Charging Port Replacement: step 15, image 2 of 3 OnePlus 9 Pro Charging Port Replacement: step 15, image 3 of 3
      • Unclip the ribbon cable on bottom left side of the daughter board, using the spudger.
      • Insert a spudger under the lip of the upper-left interconnect cable press connector and pry it straight up to disconnect it.
      Ask FixBot
    4. OnePlus 9 Pro Charging Port Replacement: step 16, image 1 of 1
      • Use a spudger to pry the coaxial network cables straight up to disconnect them.
      • Everything should be fully disconnected from the daughterboard.
      Ask FixBot
    5. OnePlus 9 Pro Charging Port Replacement: step 17, image 1 of 1
      • Pry out the daughter board out from the top using the spudger.
      Ask FixBot
    6. OnePlus 9 Pro Charging Port Replacement: step 18, image 1 of 2 OnePlus 9 Pro Charging Port Replacement: step 18, image 2 of 2
      • Pry off the USB charging port and the ribbon cable with the spudger by prying it on the right side.
      • Remove the charging port.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Author
with
Brayan Santana
873 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 38
Past 30 Days: 226
All Time: 2,512
