Up to 20% off select tools
Guides
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Troubleshooting
If you have any additional issues with your Nest x Yale Lock then head to the troubleshooting page.
Background Information
The Nest X Yale is a locking door device and home defense system controlled by an app that was released in March 2018 (smarthomexperience.com). The price is $279.00 USD (On Tech Smart Services-1). There were no recalls known about this device at this time. The Nest X Yale lock made "The Best Smart Locks of 2022" on Tom’s Guide. Some parts of the device that can malfunction or fail are the camera, touch screen, battery, Wi-Fi, audio, and the lock. It fits with the rest of the family of locks because its works just like any other device in the family. The old model that was replaced is called Yale assure lock, it was replaced because the Nest X Yale lock was easier to use and had an updated design. The device that replaced Nest X Yale was August Smart Lock Pro because it fits on the deadbolt on the door and has texture to add grip.
Identification
The Nest x Yale lock is a small lock that has three different parts. The first is the keypad that is outside. Then the inside of the lock faces inwards. Both the lock and keypad should have an icon on the top that says “Yale”. As well as the connectivity device which is the Nest Connect or Nest Guard which has text that is hard to see but should say “Yale”.
Specifications
Dimensions:
Outside
Height: 4.59 inches (11.66 cm)
Width: 2.59 inches (6.58 cm)
Depth: .80 inches (1.79 cm)
Inside
Height: 7.03 inches (17.88 cm)
Width: 2.78 inches (6.58 cm)
Depth: 2.02 inches (5.12 cm)
Weight
2 lb 4.2 oz (1.03 kg)
Power requirements
4 AA batteries (included)
Sensors
Optical Capacitive touch
Audio
Talking lock with input chime
Lights
LED keypad
Operating Temperatures
–22° to 140°F (–30° to 60°C)
Colors
Satin Nickel, Oil Rubbed Bronze, Polished Brass
Additional Information
Official Nest x Yale Product Website
Google Troubleshooting Help Page
Nest x Yale Lock Review on TechRadar
Comparison of the Nest x Yale Lock and the Yale Assure Lock
Comparison of the Nest x Yale lock and the August Smart Lock
Author
with
Bryant Yanez Gonzalez
51 Reputation
0 Guides authored
CSU Los Angeles, Team 5-3, Adachi Fall 2022 Member of CSU Los Angeles, Team 5-3, Adachi Fall 2022
CSULA-ADACHI-F22S5G3
5 Members
60 Guides authored
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 67
All Time: 2,534
