Nest x Yale Lock Keypad Replacement
    1. Nest x Yale Lock Keypad Replacement, Keypad: step 1, image 1 of 1
      • Unscrew all available screws that you can see from the back.
      • The screws are 0.25 inches phillips screws.
      • Make sure to not lose any of the screws, and keep track of them.
      Ask FixBot
    2. Nest x Yale Lock Keypad Replacement: step 2, image 1 of 1
      • Once you have unscrewed all the screws carefully remove the metal covering.
      • Make sure that the wire safely goes through the hole.
      Ask FixBot
    3. Nest x Yale Lock Keypad Replacement: step 3, image 1 of 1
      • Then once again unscrew the two screws that you see.
      • The screws have a height of 0.2 inches phillips screws.
      Ask FixBot
    4. Nest x Yale Lock Keypad Replacement: step 4, image 1 of 2 Nest x Yale Lock Keypad Replacement: step 4, image 2 of 2
      • Once all screws are unscrewed proceed to tap the screen out of the metal casing.
      Ask FixBot
Christopher Gonzalez
313 Reputation
3 Guides authored
CSU Los Angeles, Team 5-3, Adachi Fall 2022 Member of CSU Los Angeles, Team 5-3, Adachi Fall 2022
CSULA-ADACHI-F22S5G3
5 Members
60 Guides authored
1 Guide Comment
Where do you order the touchscreen from?
Mike Turrell - Reply Share
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 46
All Time: 754
