Antenna Bar
1 Answer 0 Score |
MacBook Pro A2991 battery interface |
2 Answers 0 Score |
Is it possible to use an iPhone nand to upgrade storage |
1 Answer 1 Score |
Battery issues after screen replacement |
1 Answer 1 Score |
Source of strong magnetic fields on the front corners of case |
Parts
- MacBook Pro and MacBook Air (A2442, A2485, A2681, A2779, A2780, A2941, A2991, A2918, A2992, A3112, A3113, A3114, A3185, A3186, A3401, A3403) Key Caps
- MacBook Pro 14" (A2442, A2779, A2918, A2992) and 16" (A2485, A2780, A2991) Keyboard
- MacBook Pro 14" (A2442, A2779, A2918, A2992) and 16" (A2485, A2780, A2991) USB-C Board
- MacBook Pro 14" (A2442, A2779, A2918, A2992) and 16" (A2485, A2780, A2991) MagSafe 3 DC-In Board
- MacBook Pro 16" (A2485, A2780, A2991) Microphone
- MacBook Pro and MacBook Air USB-C to MagSafe 3 Cable
- MacBook Pro 16" (A2485, A2780, A2991) Left Fan
- MacBook Pro 14" (A2442, A2779, A2918, A2992) and 16" (A2485, A2780, A2991) Display Cable Brackets
Tools
- iFixit Precision 4 mm Screwdriver Bit
- Spudger
- iFixit Opening Picks (Set of 6)
- Tweezers
- Suction Handle
- Microfiber Cleaning Cloths
- iFixit Precision Bit Driver, Aluminum
- Plastic Cards
- P5 Pentalobe Screwdriver Retina MacBook Pro and Air
- Lint-Free Clean Room Wipes
- IA-3952 - Max Professional Consumable Isopropyl Alcohol
Models
A2991 EMC 8408 2023 Mac15,11 4.05 GHz M3 Max 14-Core Processor/30-Core GPU/16-Core Neural Engine, A2991 EMC 8408 2023 Mac15,7 4.05 GHz M3 Pro 12-Core Processor/18-Core GPU/16-Core Neural Engine, A2991 EMC 8408 2023 Mac15,9 4.05 GHz M3 Max 16-Core Processor/40-Core GPU/16-Core Neural Engine
Background
Released in November 2023, the latest 16" MacBook Pro gets an upgrade with Apple's also-new-for-late-2023 M3 Pro and M3 Max SoCs, featuring up to 12-core or 16-core CPUs and up to 18-core or 40-core GPUs respectively. Both the updated 16" MacBook Pro and its smaller 14" MacBook Pro sibling share many of the same features found in early 2023 MacBook Pros, including the same ports, ProMotion HDR mini-LED displays, 1080p webcams with a display notch, full-size function keys, and the distinctive blacked-out keyboard. Small, yet notable other upgrades for late 2023 include a slightly larger battery and a new color option—Space Black.
Starting at a price of $2499, the late 2023 16" MacBook Pro is available in either Silver or Space Black.
Identification
Identify your MacBook Pro by the model number printed on its back cover.
You can also find the model number through macOS by choosing About This Mac from the Apple menu in the upper-left corner of the screen.
Additionally, Apple offers a quick online tool to help identify your devices: Identify your MacBook Pro model.
Technical Specifications
Display
- 16.2" Liquid Retina XDR mini-LED display with True Tone; 3456 x 2234 pixels (254 ppi); ProMotion adaptive refresh rate (up to 120 Hz); HDR, P3 wide color gamut; 1000 nits sustained, 1600 nits peak brightness
Processor
- Apple M3 Pro 12-core CPU, 16-core Neural Engine
- (Configurable to) Apple M3 Max 14-core CPU, 16-core Neural Engine
- (Configurable to) Apple M3 Max 16-core CPU, 16-core Neural Engine
Graphics
- Apple M3 Pro integrated 18-core GPU
- (Configurable to) Apple M3 Max integrated 30-core GPU
- (Configurable to) Apple M3 Max integrated 40-core GPU
Storage
- 512 GB PCIe-based SSD, configurable to 1 TB, 2 TB, 4 TB, or 8 TB
Memory
- 18 GB of unified LPDDR5 memory, configurable to 36 GB, 48 GB, 64 GB, 96 GB, or 128GB
Wireless
- 802.11ax Wi-Fi 6E wireless networking; IEEE 802.11a/b/g/n/ac compatible
- Bluetooth 5.3 wireless technology
Battery
- Built-in 100-watt-hour lithium-polymer battery
- Up to 15 hours of web browsing, up to 22 hours of Apple TV app video playback
Dimensions
- Height: 0.66 in (1.68 cm)
- Width: 14.01 in (35.57 cm)
- Depth: 9.77 in (24.81 cm)
- Weight: M3 Pro: 4.7 lbs (2.14 kg), M3 Max: 4.8 lbs (2.16 kg)
Ports
- MagSafe 3 charging port
- 3× Thunderbolt USB-C ports (Thunderbolt 4 / USB 4 / DisplayPort / charging)
- HDMI 2.1 port
- SDXC card slot
- 1× 3.5 mm headphone jack
