MacBook Pro A2991 battery interface
Hi everyone,
I recently damaged a connector while replacing the battery in my laptop.
I was wondering if it would be possible to solder and desolder this connector using a hot air rework gun.
Has anyone had experience repairing this type of connector this way? Would it be safe, or is there a risk of damaging the motherboard?
Many thanks!
JOAN
Actualización (11/16/26)
Hello, I am not sure if this thing will get out. What do you think?
3 Comments
Can you say which exact model it is?
by livfe Share
Macbook Pro 16" M3 2023 A2991, thanks!
by Joan Share
@fuster - Do you have a Hot Air rework station?
The trick to remove the remaining ribbon interface is adding solder to the exposed pads so the heat can pass to the underside. As you heat the ribbon with the hot air keeping the solder on top hot the remains show slide off a bit and with a quick lift fully off.
by DanJ Share
