Antenna Bar
1 Answer 0 Score |
Screen replacement issue MacBook Pro m4 16" max 2024 |
No Answers 0 Score |
Water Spill Fans Running Constant Partial FIx |
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
A3186 EMC 8624 2024 Mac16,5 4.5 GHz M4 Max 14-Core Processor/32-Core GPU/16-Core Neural Engine, A3186 EMC 8624 2024 Mac16,5 4.5 GHz M4 Max 16-Core Processor/40-Core GPU/16-Core Neural Engine, A3403 EMC 8895 2024 Mac16,7 4.5 GHz M4 Pro 14-Core Processor/20-Core GPU/16-Core Neural Engine
Background
Announced in October 2024—alongside the redesigned Mac mini, refreshed 2024 24" iMac, and the smaller 14-inch MacBook Pros—the larger 16-inch MacBook Pro is updated once again with the next generation of higher-end Apple silicon: the M4 Pro and M4 Max. And, to support Apple Intelligence, 16-inch model base memory increases from 18 to 24 GB.
The 16" MacBook Pro shares many of the same features introduced in 2021 and 2023's MacBook Pros, including ProMotion HDR mini-LED displays, 1080p webcams with a display notch, full-size function keys, and the distinctive blacked-out keyboard.
Starting at a $2499, the 2024 16" MacBook Pro is available in either Silver or Space Black.
Identification
Identify your MacBook Pro by the model number printed on its back cover.
You can also find the model number through macOS by choosing About This Mac from the Apple menu in the upper-left corner of the screen.
Additionally, Apple offers a quick online tool to help identify your devices: Identify your MacBook Pro model.
The 2024 MacBook Pro features a large flat glass screen, thin black bezels, a "notch" cutout at the top of the screen, black keys, and an aluminum enclosure. There's a large gloss black Apple logo on the top shell and "MacBook Pro" engraved into the bottom case.
A MagSafe 3 charging port, two USB-C ports, and a headphone jack can be found on the left edge, with an additional USB-C port, HDMI port, and an SD card slot on the right.
Technical Specifications
Display
- 16.2" Liquid Retina XDR mini-LED display with True Tone; 3456 x 2234 pixels (254 ppi); ProMotion adaptive refresh rate (up to 120 Hz); HDR, P3 wide color gamut; 1000 nits sustained (indoor and outdoor), 1600 nits peak brightness, nano-texture display option
Processor
- Apple M4 Pro 14-core CPU, 16-core Neural Engine
- Configurable to M4 Max 14-core CPU
- Configurable to M4 Max 16-core CPU
Graphics
- Apple M4 Pro integrated 20-core GPU
- Configurable to M4 Max 32-core GPU
- Configurable to M4 Max 40-core GPU
Storage
- 512 GB PCIe-based SSD, configurable to 1, 2, 4, or 8 TB.
Memory
- 24 GB of unified memory, configurable to 36, 48, 64, or 128 GB.
Wireless
- 802.11ax Wi-Fi 6E wireless networking; IEEE 802.11a/b/g/n/ac compatible
- Bluetooth 5.3 wireless technology
Battery
- Built-in 100 Wh lithium-polymer battery
Dimensions
- Height: 0.66 in (1.68 cm)
- Width: 14.01 in (35.57 cm)
- Depth: 9.77 in (24.81 cm)
- Weight: 4.7 lbs (2.14–2.15 kg)
Ports
- MagSafe 3 charging port
- 3× Thunderbolt 5 USB-C ports (120 Gb/s / DisplayPort / charging)
- HDMI 2.1 port
- SDXC card slot
- 1× 3.5 mm headphone jack
