MacBook Pro 16" 2024 (M4) Screen Replacement
    1. MacBook Pro 16" 2024 (M4) Screen Replacement, Prepare your MacBook for disassembly: step 1, image 1 of 3 MacBook Pro 16" 2024 (M4) Screen Replacement, Prepare your MacBook for disassembly: step 1, image 2 of 3 MacBook Pro 16" 2024 (M4) Screen Replacement, Prepare your MacBook for disassembly: step 1, image 3 of 3
      • Allow your MacBook's battery to drain below 10% before starting this repair. A charged battery may catch fire if damaged during the repair.
      • Fully shut down your MacBook, close the lid, and flip it over. Keep the lid closed until you've physically disconnected the battery.
      • Unplug the MagSafe cable and any accessories connected to your MacBook.
      Ask FixBot
    1. MacBook Pro 16" 2024 (M4) Screen Replacement, Unfasten the lower case: step 2, image 1 of 2 MacBook Pro 16" 2024 (M4) Screen Replacement, Unfasten the lower case: step 2, image 2 of 2
      Tool used on this step:
      FixMat
      $36.95
      Buy
      • Completely power off and unplug your MacBook Pro before you start. Close the screen and flip the entire laptop upside-down.
      • Use a P5 Pentalobe driver to remove eight screws securing the lower case:
      • Four 9.2 mm screws
      • Four 5 mm screws
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
      Ask FixBot
    2. MacBook Pro 16" 2024 (M4) Screen Replacement, Unclip the lower case: step 3, image 1 of 2 MacBook Pro 16" 2024 (M4) Screen Replacement, Unclip the lower case: step 3, image 2 of 2
      • Press a suction handle into place near the front edge of the lower case, between the screw holes.
      • Pull up on the suction handle to create a small gap under the lower case.
      Ask FixBot
    3. MacBook Pro 16" 2024 (M4) Screen Replacement, Release the lower case's right clips: step 4, image 1 of 3 MacBook Pro 16" 2024 (M4) Screen Replacement, Release the lower case's right clips: step 4, image 2 of 3 MacBook Pro 16" 2024 (M4) Screen Replacement, Release the lower case's right clips: step 4, image 3 of 3
      • Insert an opening pick into the gap you just created.
      • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
      • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
      Ask FixBot
    4. MacBook Pro 16" 2024 (M4) Screen Replacement, Release the rear cover's left clips: step 5, image 1 of 3 MacBook Pro 16" 2024 (M4) Screen Replacement, Release the rear cover's left clips: step 5, image 2 of 3 MacBook Pro 16" 2024 (M4) Screen Replacement, Release the rear cover's left clips: step 5, image 3 of 3
      • Repeat the previous step on the other side, using an opening pick to to release the second clip.
      Ask FixBot
    5. MacBook Pro 16" 2024 (M4) Screen Replacement, Release the sliding clips: step 6, image 1 of 3 MacBook Pro 16" 2024 (M4) Screen Replacement, Release the sliding clips: step 6, image 2 of 3 MacBook Pro 16" 2024 (M4) Screen Replacement, Release the sliding clips: step 6, image 3 of 3
      • Sliding clips along the back edge of the MacBook further secure the lower case. Separating these clips may require a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
      • Firmly pull the lower case away from the back edge, one corner at a time, to disengage the sliding clips.
      • Keep the lower case flat to the MacBook. Don't pull upward until it's completely separated.
      Ask FixBot
    6. MacBook Pro 16" 2024 (M4) Screen Replacement, Remove the lower case: step 7, image 1 of 3 MacBook Pro 16" 2024 (M4) Screen Replacement, Remove the lower case: step 7, image 2 of 3 MacBook Pro 16" 2024 (M4) Screen Replacement, Remove the lower case: step 7, image 3 of 3
      • Remove the lower case.
      • To reinstall the lower case:
      • Set it in place and align the sliding clips near the screen hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
      • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
      Ask FixBot
    1. MacBook Pro 16" 2024 (M4) Screen Replacement, Disconnect the battery board: step 8, image 1 of 3 MacBook Pro 16" 2024 (M4) Screen Replacement, Disconnect the battery board: step 8, image 2 of 3 MacBook Pro 16" 2024 (M4) Screen Replacement, Disconnect the battery board: step 8, image 3 of 3
      • Peel back any tape covering the battery board data cable connector on the logic board.
      Ask FixBot
    2. MacBook Pro 16" 2024 (M4) Screen Replacement: step 9, image 1 of 2 MacBook Pro 16" 2024 (M4) Screen Replacement: step 9, image 2 of 2
      • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
      Ask FixBot
    3. MacBook Pro 16" 2024 (M4) Screen Replacement: step 10, image 1 of 2 MacBook Pro 16" 2024 (M4) Screen Replacement: step 10, image 2 of 2
      • Disconnect the battery board data cable by sliding it out from its socket on the logic board.
      Ask FixBot
    4. MacBook Pro 16" 2024 (M4) Screen Replacement, Unfasten the trackpad cable bracket: step 11, image 1 of 1
      • Use a 3IP Torx Plus driver to remove the two 2.1 mm‑long screws securing the trackpad cable bracket to the logic board.
      Ask FixBot
    5. MacBook Pro 16" 2024 (M4) Screen Replacement, Remove the trackpad cable bracket: step 12, image 1 of 2 MacBook Pro 16" 2024 (M4) Screen Replacement, Remove the trackpad cable bracket: step 12, image 2 of 2
      Buy
      • Use tweezers, or your fingers, to remove the trackpad cable bracket.
      Ask FixBot
    6. MacBook Pro 16" 2024 (M4) Screen Replacement, Disconnect the trackpad cable: step 13, image 1 of 2 MacBook Pro 16" 2024 (M4) Screen Replacement, Disconnect the trackpad cable: step 13, image 2 of 2
      • Use the flat end of a spudger to pry up and disconnect the trackpad cable's press connector from the logic board.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    7. MacBook Pro 16" 2024 (M4) Screen Replacement, Reposition the trackpad cable: step 14, image 1 of 2 MacBook Pro 16" 2024 (M4) Screen Replacement, Reposition the trackpad cable: step 14, image 2 of 2
      • The trackpad cable is lightly adhered to the frame.
      • Peel the trackpad cable away from the device, making sure to separate the adhesive.
      Ask FixBot
    8. MacBook Pro 16" 2024 (M4) Screen Replacement, Disconnect the battery board: step 15, image 1 of 2 MacBook Pro 16" 2024 (M4) Screen Replacement, Disconnect the battery board: step 15, image 2 of 2
      • Peel back any tape covering the battery board data cable connector under the large pancake screw.
      Ask FixBot
    9. MacBook Pro 16" 2024 (M4) Screen Replacement: step 16, image 1 of 2 MacBook Pro 16" 2024 (M4) Screen Replacement: step 16, image 2 of 2
      Ask FixBot
    10. MacBook Pro 16" 2024 (M4) Screen Replacement: step 17, image 1 of 2 MacBook Pro 16" 2024 (M4) Screen Replacement: step 17, image 2 of 2
      • Disconnect the battery board data cable by sliding it out from its socket on the battery board.
      Ask FixBot
    11. MacBook Pro 16" 2024 (M4) Screen Replacement, Remove the data cable: step 18, image 1 of 2 MacBook Pro 16" 2024 (M4) Screen Replacement, Remove the data cable: step 18, image 2 of 2
      • The battery board data cable is lightly adhered to the device.
      • Slide blunt nose tweezers under areas with adhesive to separate the cable from the device.
      • Remove the battery board data cable.
      Ask FixBot
    12. MacBook Pro 16" 2024 (M4) Screen Replacement, Unfasten the battery connector: step 19, image 1 of 1
      • Use a 5IP Torx Plus driver to remove the 4 mm pancake screw securing the battery power connector.
      Ask FixBot
    13. MacBook Pro 16" 2024 (M4) Screen Replacement, Disconnect the battery connector: step 20, image 1 of 3 MacBook Pro 16" 2024 (M4) Screen Replacement, Disconnect the battery connector: step 20, image 2 of 3 MacBook Pro 16" 2024 (M4) Screen Replacement, Disconnect the battery connector: step 20, image 3 of 3
      • Use the flat end of your spudger to lift the battery connector away from the battery board, disconnecting the battery.
      • Lift the connector high enough that it doesn't accidentally make contact during the repair, but no more than 45 degrees to prevent damaging its hinge.
      • For added safety, place a barrier, such as a piece of a playing card, between the connector and board.
      Ask FixBot
    1. MacBook Pro 16" 2024 (M4) Screen Replacement, Unfasten the antenna bar's connector bracket: step 21, image 1 of 2 MacBook Pro 16" 2024 (M4) Screen Replacement, Unfasten the antenna bar's connector bracket: step 21, image 2 of 2
      • Use a 3IP Torx Plus screwdriver to remove the three 2.1 mm screws securing the antenna board bracket and coaxial cable cover to the frame.
      Ask FixBot
    2. MacBook Pro 16" 2024 (M4) Screen Replacement: step 22, image 1 of 2 MacBook Pro 16" 2024 (M4) Screen Replacement: step 22, image 2 of 2
      Buy
      • Use tweezers, or your fingers, to remove the cover on top of the antenna bar's coaxial cables.
      Ask FixBot
    3. MacBook Pro 16" 2024 (M4) Screen Replacement, Disconnect the antenna bar: step 23, image 1 of 2 MacBook Pro 16" 2024 (M4) Screen Replacement, Disconnect the antenna bar: step 23, image 2 of 2
      • Use the tip of a spudger to pry up and disconnect the antenna bar's coaxial cable.
      • Repeat for the two other cables.
      • During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
      Ask FixBot
    4. MacBook Pro 16" 2024 (M4) Screen Replacement, Unfasten the antenna bar: step 24, image 1 of 2 MacBook Pro 16" 2024 (M4) Screen Replacement, Unfasten the antenna bar: step 24, image 2 of 2
      • Use a 5IP Torx Plus screwdriver to remove the six screws securing the antenna bar to the frame:
      • Two 7.5 mm screws
      • Four 3 mm screws
      • Use a P2 Pentalobe driver to remove the nine 1.5 mm screws securing the antenna bar to the frame.
      • These screws strip very easily; use constant downward pressure and work slowly when you loosen these.
      Ask FixBot
    5. MacBook Pro 16" 2024 (M4) Screen Replacement, Remove the antenna bar: step 25, image 1 of 2 MacBook Pro 16" 2024 (M4) Screen Replacement, Remove the antenna bar: step 25, image 2 of 2
      • Insert the tip of a spudger between the antenna bar and the frame.
      • Pry up with the spudger to separate the antenna bar from the frame.
      Ask FixBot
    6. MacBook Pro 16" 2024 (M4) Screen Replacement: step 26, image 1 of 2 MacBook Pro 16" 2024 (M4) Screen Replacement: step 26, image 2 of 2
      • Pull the antenna bar straight up and out of the frame to remove it.
      Ask FixBot
    1. MacBook Pro 16" 2024 (M4) Screen Replacement, Unfasten the screen cable covers: step 27, image 1 of 2 MacBook Pro 16" 2024 (M4) Screen Replacement, Unfasten the screen cable covers: step 27, image 2 of 2
      • Use a 3IP Torx Plus driver to remove the four 3.5 mm screws securing the screen cable covers.
      Ask FixBot
    2. MacBook Pro 16" 2024 (M4) Screen Replacement, Remove the screen cable covers: step 28, image 1 of 2 MacBook Pro 16" 2024 (M4) Screen Replacement, Remove the screen cable covers: step 28, image 2 of 2
      Buy
      • Use tweezers, or your fingers, to remove the two screen cable covers from the logic board.
      Ask FixBot
    3. MacBook Pro 16" 2024 (M4) Screen Replacement, Disconnect the screen cables: step 29, image 1 of 3 MacBook Pro 16" 2024 (M4) Screen Replacement, Disconnect the screen cables: step 29, image 2 of 3 MacBook Pro 16" 2024 (M4) Screen Replacement, Disconnect the screen cables: step 29, image 3 of 3
      • Use the flat end of a spudger to pry up and disconnect the right-most screen cable press connectors secured to the logic board.
      Ask FixBot
    4. MacBook Pro 16" 2024 (M4) Screen Replacement: step 30, image 1 of 2 MacBook Pro 16" 2024 (M4) Screen Replacement: step 30, image 2 of 2
      • Repeat the previous step for the left-most press connector.
      Ask FixBot
    5. MacBook Pro 16" 2024 (M4) Screen Replacement, Remove the screen cable brackets: step 31, image 1 of 3 MacBook Pro 16" 2024 (M4) Screen Replacement, Remove the screen cable brackets: step 31, image 2 of 3 MacBook Pro 16" 2024 (M4) Screen Replacement, Remove the screen cable brackets: step 31, image 3 of 3
      • Pull up on the back of the screen cable bracket to release the clips securing it to the frame.
      • Remove the screen cable bracket.
      • Repeat for the other screen cable bracket.
      Ask FixBot
    6. MacBook Pro 16" 2024 (M4) Screen Replacement: step 32, image 1 of 2 MacBook Pro 16" 2024 (M4) Screen Replacement: step 32, image 2 of 2
      • If the two screen cable bracket buffers are removed alongside the brackets, then skip this step.
      • Pull the two screen cable bracket buffers straight up and out of the frame to remove them.
      Ask FixBot
    7. MacBook Pro 16" 2024 (M4) Screen Replacement, Unfasten the lid angle sensor cover: step 33, image 1 of 2 MacBook Pro 16" 2024 (M4) Screen Replacement, Unfasten the lid angle sensor cover: step 33, image 2 of 2
      • Use a 3IP Torx Plus driver to remove the two 2.1 mm screws securing the lid angle sensor cover near the right hinge.
      Ask FixBot
    8. MacBook Pro 16" 2024 (M4) Screen Replacement, Remove the lid angle sensor cover: step 34, image 1 of 1
      • Use tweezers, or your fingers, to remove the lid angle sensor cover.
      Ask FixBot
    9. MacBook Pro 16" 2024 (M4) Screen Replacement, Disconnect the lid angle sensor cable: step 35, image 1 of 2 MacBook Pro 16" 2024 (M4) Screen Replacement, Disconnect the lid angle sensor cable: step 35, image 2 of 2
      • Use the flat of a spudger to pry up and disconnect the lid angle sensor's press connector.
      Ask FixBot
    10. MacBook Pro 16" 2024 (M4) Screen Replacement, Unfasten the hinge covers: step 36, image 1 of 2 MacBook Pro 16" 2024 (M4) Screen Replacement, Unfasten the hinge covers: step 36, image 2 of 2
      • Use a 5IP Torx Plus driver to remove the four 2.5 mm screws securing the hinge covers (two screws on each side).
      Ask FixBot
    11. MacBook Pro 16" 2024 (M4) Screen Replacement, Remove the hinge covers: step 37, image 1 of 3 MacBook Pro 16" 2024 (M4) Screen Replacement, Remove the hinge covers: step 37, image 2 of 3 MacBook Pro 16" 2024 (M4) Screen Replacement, Remove the hinge covers: step 37, image 3 of 3
      • Use tweezers to pull the hinge covers horizontally away from the hinge to separate them from the frame.
      • Remove the hinge covers.
      Ask FixBot
    12. MacBook Pro 16" 2024 (M4) Screen Replacement, Remove some of the hinge screws: step 38, image 1 of 2 MacBook Pro 16" 2024 (M4) Screen Replacement, Remove some of the hinge screws: step 38, image 2 of 2
      • Use a 8IP Torx Plus driver to remove two 6.4 mm screws from each hinge (four screws total).
      • Each hinge has a third screw, which you should leave in place for now.
      Ask FixBot
    13. MacBook Pro 16" 2024 (M4) Screen Replacement, Protect the MacBook: step 39, image 1 of 2 MacBook Pro 16" 2024 (M4) Screen Replacement, Protect the MacBook: step 39, image 2 of 2
      • If you plan to re-use your screen, open it and apply a piece of tape to the glass directly above each hinge. This helps protect the glass from getting scratched in the following three steps.
      • Fully open the screen and stand your MacBook Pro up on one side.
      Ask FixBot
    14. MacBook Pro 16" 2024 (M4) Screen Replacement, Remove the remaining screws: step 40, image 1 of 3 MacBook Pro 16" 2024 (M4) Screen Replacement, Remove the remaining screws: step 40, image 2 of 3 MacBook Pro 16" 2024 (M4) Screen Replacement, Remove the remaining screws: step 40, image 3 of 3
      • Use n 8IP Torx Plus driver to remove the two remaining 6.4 mm screws (one from each hinge).
      • Remove the topmost screw last, using one hand to steady both halves of the MacBook Pro to make sure they don't separate and fall over unexpectedly.
      Ask FixBot
    15. MacBook Pro 16" 2024 (M4) Screen Replacement, Remove the screen: step 41, image 1 of 3 MacBook Pro 16" 2024 (M4) Screen Replacement, Remove the screen: step 41, image 2 of 3 MacBook Pro 16" 2024 (M4) Screen Replacement, Remove the screen: step 41, image 3 of 3
      • Keep a firm grip on both the screen and main body of the MacBook Pro. Either half can fall unexpectedly during this step.
      • Push both halves of the MacBook Pro together so that the hinges can be lifted clear of their recesses in the chassis.
      • Push the main body of the MacBook Pro away from you while pulling the screen toward you to separate it.
      Ask FixBot
    16. MacBook Pro 16" 2024 (M4) Screen Replacement: step 42, image 1 of 1
      • Remove the screen.
      Ask FixBot
    17. MacBook Pro 16" 2024 (M4) Screen Replacement: step 43, image 1 of 2 MacBook Pro 16" 2024 (M4) Screen Replacement: step 43, image 2 of 2
      • If desired, add a little blue threadlocker to the screw threads to prevent them from loosening over time.
      • During reassembly, first install the hinge screws without tightening them fully. Then adjust the screen until it is correctly centered and aligned on each side. Finally, tighten the screws.
      • If your screen clicks or snaps upon opening, loosen the hinge screws and adjust the alignment. Make sure the screen doesn't sit too far forward, or it can catch on the body when opening and closing.
      Ask FixBot
Arthur Shi
348,207 Reputation
929 Guides authored
0 Guide Comments
Past 24 Hours: 18
Past 7 Days: 128
Past 30 Days: 349
All Time: 566
