Up to 20% off select tools
Guides
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
212CN
Background
Released in 2015, MSI's GT72 2QE Dominator Pro is designed for high-quality gaming. The laptop comes with Windows 8 and an Intel i7 Processor. In addition, it also comes with a Nvidia GTX 980M graphics card, which can power multiple monitors using Matrix Display and can output 4k resolution. It has a 17.3 inch screen, is about 2 inches thick and weighs about 8 pounds.
Identification
The 2QE model can easily be differentiated from its predecessor from its updated dimensions to the new color keyboard. Its predecessor the MSI GT70 was 2.25 inches thick and the 2QE is 1.89". The new color backlight keyboard stands out from the previous white backlight.
Technical Specifications
Display
  • 17.3" Full HD (1920x1080)
Storage
  • Up to 1024GB Super RAID 3 + 1TB HDD 7200rpm
Processor
  • 5th Gen. Intel® Core™ i7 5950HQ / 5700HQ
Memory
  • DDR3L,up to 1600 MHz, slot *4, max 32GB
Wireless Connectivity
  • Killer DoubleShot Pro 11ac
  • Killer DoubleShot Pro Gb LAN
  • Bluetooth v4.0
Graphics
  • GeForce GTX 980M with 4GB/8GB GDDR5 RAM
Optical Drive
  • BD Writer / DVD Super Multi
Audio
  • Sound by Dynaudio 2.1 channel with 1 Woofer
  • Support 7.1 channel SPDIF output
  • Exclusive Audio Boost 2 technology
  • Nahimic sound technology
Ports
  • SD (XC/HC) Card Reader
  • 6 or 4 + 2 USB 3.1
  • HDMI: 1 (Support 4K@30Hz)
  • 2(v1.2) Mini-DisplayPort
  • 1 Microphone/Headphone port
Dimensions
  • Width 16.85" (428mm)
  • Height 1.89" (48mm)
  • Depth 11.57" (294mm)
  • Weight 8.3lbs (3.78kg)
Specifications
Additional Information
Author
with
Ankit Maurya
201 Reputation
1 Guide authored
Cal Poly, Team S17-G2, Banghart Spring 2017 Member of Cal Poly, Team S17-G2, Banghart Spring 2017
CPSU-BANGHART-S17S17G2
5 Members
60 Guides authored
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 65
All Time: 10,058
