Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Logitech Zone Wireless 2 ES for business is part of Logitech’s Zone headset lineup, built specifically for individuals who work in hybrid or remote environments. Compared to the Wireless 2, the 2 ES sports a headband, newer Bluetooth version, and slightly different build.
It features adaptive active noise cancellation (ANC) for blocking out ambient sound and has dual noise-canceling beamforming microphones. The mics are backed by an AI-based noise suppression algorithm to reduce background noise for the person on the other end of the call. The headset also includes auto-mute when flipped up and auto-pause/play when it’s taken off or put back on.
Identification
The Zone Wireless 2 ES for Business comes in Off-white, Rose, and Graphite.
The Model Number (M/N), Part Number (P/N), and Serial Number (S/N) is located on the driver subassembly on the side without the mic boom. To view it, remove the ear pad by rotating it counterclockwise—it's printed underneath.
The Part Number (P/N) varies depending on color, configuration, and localization.
Technical Specifications
Dimensions
  • Depth: 2.87 in (73 mm)
  • Width: 7.23 in (183.6 mm)
  • Height: 7.29 in (185.2 mm)
  • Weight: 7.48 oz (212 g)
Headphones
  • Frequency response (music mode): 20-20KHz
  • Frequency response (talk mode): 100-8KHz
  • Audio Drivers: 1.57 in (40 mm)
Microphone
  • 2 noise-cancelling mics
  • Frequency response: 100 Hz–8 KHz
Wireless Technology
  • Bluetooth 5.3
Battery
  • Lithium-ion battery
  • Battery life: up to 25 hours (talk time)
  • Battery life: up to 48 hours (listening time)
  • USB-C charging port
Additional Information
Arthur Shi
354,370 Reputation
938 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 46
All Time: 473
