Up to 20% off select tools
Guides
Documents
Models
80R4
Lenovo Flex 3 1480 Flex 3 1580 Hmm 201509
Background
The Lenovo Flex 3-1580 uses a Flex chassis, weighing at 5.1 pounds (2.3 kg). This design includes a full 360-degree flip around screen.
Out of the Flex series there is a Lenovo Flex 3-1480 that was released at the same time. This will have a small screen at 14 inches, weighing slightly less at 4.4 lb vs the 4.6 lb in the Flex 3-1580. No recalls were ever initiated.
Most if not all laptops, when you flip these over, you should see a black label in the center. This will have the model number and as well the device name (Flex 3-1580).
Identification
This model number can be located on the bottom of the device, typically in the center with a black label with a barcode on the bottom. This will have the name and serial number as well. The Lenovo Flex 3-1580 is a compact device, but compared to the 1480, it has a slightly bigger screen.
The Lenovo flex 3-1580 comes in all black, equipped with touch screen capabilities and 360-flip screen, and can utilize as a laptop or tablet if needed. No distinct markings other than the Lenovo logo on the top side of the device, and a 6 row full size keyboard.
Released in 2016, with no manufacture recall notices released.
Technical Specifications
Graphic memory chip
  • Integrated Graphics: GT2
  • Discreted Graphics (optional): Integrated/Nvidia N16V-GM/ Nvidia N16S-GT
Display
  • 14.0" 16:9, 1,366 x 768 pixels HD / 1,920 x 1,080 pixels FHD
  • 15.6" 16.9, 1,366 X 768 pixels HD / 1,920 x 1,080 pixels FHD
Standard Memory
  • 1,600 MHz SODIMM x 1 (max 8 GB)
Hard disk drive
  • 2.5-inch, 7mm SATA ll/SATA lll
  • 500 GB / 1 TB 5,400 rpm
l/O port
  • Combo audio jack x 1
  • RJ-45 x 1
  • HDMI port x 1
  • USB 2.0 port x 1, USB 3.0 port x 2
  • 4 in 1 slot x 1 (SD/SDHC/SDXC/MMC)
Audio
  • 1/8" Combo audio jack
  • 1.5 W speakers x 2
  • Single/Array Digital MIC
Ethernet (on the system board)
  • 1,000 Mbps
Bluetooth wireless
  • Combined in combo card
Keyboard
  • 6 row ISO full size keyboard
Touchpad
  • Multi-touch type
Integrated camera
  • HD/0.3M
Battery
  • 3cells / 2 cells, 45 Wh / 30 Wh
AC adapter
  • DIS 65 W, UMA 45 W
Pre-installed operating system
  • Linpus lite/DOS
  • Windows Mobile
  • Windows 10 (or similar update in 13 months)
Additional Information
Lenovo Flex 3-1580 Manual
Lenovo Drivers & Software
Lenovo Parts
Lenovo FLEX 3-1480 and FLEX 3-1580 User Guide
Author
with
Max Kletskov
42,382 Reputation
16 Guides authored
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 60
All Time: 1,661
