Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background and Identification
A hard disk drive (HDD), hard disk, hard drive, or fixed disk is an electromechanical data storage device that uses magnetic storage to store and recall digital data using rapidly rotating plates coated with magnetic material. The plates are paired with magnetic hears that are usually arranged on a moving actuator arm and are designed to read and write data to the plate surfaces. Stored data is accessed in a random-accessed manner, meaning that blocks of data can be stored and recalled in any order. Hard drives retain stored data even when powered off, making them a type of non-volatile storage.
Hard drives were introduced by IBM in 1956 as the dominant secondary storage device for computers. Hard drives became the main storage devices for servers and personal computers, as well, though personal computers produced en masse, like tablets and cell phones, rely on flash products. Historically, over 224 companies have produced hard drives.
Solid-state drives (SSDs) are also used for data storage but feature higher data-transfer rates, better reliability, higher areal storage, and lower latency and access times.
Hard drives are often characterized by capacity and performance. Capacity is generally specified with unit prefixes corresponding to powers of 1,000. For instance, a 1-terabyte (TB) hard drive has a capacity of 1,000 gigabytes (GB, where 1 gigabyte is equal to 1 billion bytes). Performance is specified by the time required to move the device’s heads to a track, or the average access time, and the data transmission rate.
Hard Drive Replacement 67-2068 Rev C
Author
with
Matthew Newsom
43,302 Reputation
67 Guides authored
Past 24 Hours: 71
Past 7 Days: 502
Past 30 Days: 2,095
All Time: 115,121
