How To Repair A Dropped External Hard Drive
    1. How To Repair A Dropped External Hard Drive, How To Repair A Dropped External Hard Drive: step 1, image 1 of 1
      • Place the flathead screwdriver in between where the case and lid meet, and pry open the external case to expose the hard drive itself.
      • Once the screwdriver head is in between the opening, slide it around the case while twisting the screwdriver in order to loosen the case.
      Ask FixBot
    2. How To Repair A Dropped External Hard Drive: step 2, image 1 of 1
      • Carefully take out the hard drive by holding the edges, and ensuring that the connector is not bent when removing from the case.
      Ask FixBot
    3. How To Repair A Dropped External Hard Drive: step 3, image 1 of 1
      • Find the end of the foil wrap that surround the hard drive, and slowly start peeling it back until all the screws are exposed.
      • You will need to apply the foil wrap again later, so be careful when removing it.
      Ask FixBot
    4. How To Repair A Dropped External Hard Drive: step 4, image 1 of 1
      • Begin unscrewing the screws on the lid of the hard drive using both the Phillips screwdriver, as well as the torx screwdriver where appropriate.
      Ask FixBot
    5. How To Repair A Dropped External Hard Drive: step 5, image 1 of 1
      • Once all the screws are removed, carefully take off the lid of the hard drive, making sure you do not touch any part of the disk itself once it is exposed.
      Ask FixBot
    6. How To Repair A Dropped External Hard Drive: step 6, image 1 of 1
      • Using the Phillips screwdriver, place it in the slot in the middle of the disk, and turn counter clockwise until the arm has been release from the disk, close to it's parked position.
      Ask FixBot
    7. How To Repair A Dropped External Hard Drive: step 7, image 1 of 1
      Tool used on this step:
      Buy
      • Once the arm has been released, use a pair of tweezers to carefully ensure the arm has been placed back into it's parked position, and is off of the disk.
      Ask FixBot
    8. How To Repair A Dropped External Hard Drive: step 8, image 1 of 1
      • Carefully place the lid back on the hard drive, making sure that you do not come in contact with the disk itself.
      Ask FixBot
    9. How To Repair A Dropped External Hard Drive: step 9, image 1 of 1
      • Use the appropriate screwdrivers to put all the screws back in their required slots.
      Ask FixBot
    10. How To Repair A Dropped External Hard Drive: step 10, image 1 of 1
      • Begin to place the foil back on the hard drive in the same position it was before removal, making sure that the LED on the hard drive is still visible and the foil is not blocking the connector.
      Ask FixBot
    11. How To Repair A Dropped External Hard Drive: step 11, image 1 of 1
      • Place the hard drive back in the external case, by inserting on a 45 degree angle with the connector going in first, and then softly pushing the hard drive down until it is back in the case and it is not sticking out.
      Ask FixBot
    12. How To Repair A Dropped External Hard Drive: step 12, image 1 of 1
      • Put the lid of the external case by pressing on both pieces until a "click" noise is heard around the case.
      Ask FixBot
6 other people completed this guide.
Nicholas
385 Reputation
1 Guide authored
3 Guide Comments
No tienes tú fe que después de abrir un disco vuelva a funcionar. Eso es una utopía.
Una mota de polvo hará que no sea lejible el disco.
Para hacer lo que ha dicho este señor se hace en cámaras limpias con instalaciones nada comunes.
Luis M - Reply Share
las instrucciones son incompletas, no explica cuando se debe hacer esta intervención y cuando no se debe hacer, cuales son los sintomas de un disco duro para hacer esta intervención?
Leonel Basoalto - Reply Share
Not bad instructions, aside from the fact that on my hard drive the Torx screws required a T4 driver...not the T3 mentioned. Still, pretty straightforward and simple...just need to plug the drive back in and see if it works.
Jack Straw Jr 2 - Reply Share
Past 24 Hours: 13
Past 7 Days: 94
Past 30 Days: 339
All Time: 12,645
