Up to 20% off select tools
How To Open A Desktop Hard Drive
Views: 3.2K
View statistics:
Past 24 Hours:
6
Past 7 Days:
48
Past 30 Days:
216
All Time:
3,214
Comments: 0
Go to guide comments
Completed: 13
13 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
  • Spudger
    4.9
    For opening up the metal front cover. Would not recommend doing so with bare hands.
Introduction
Go to step 1 ↓
Have you ever wanted to open up an old hard drive? Whether it's to permanently delete your data or to better understand how a disk drive works, I'm going to be showing you how to do it yourself. Note: Doing this is not reversible and can damage your hard drive. I am doing this on a junk hard drive, take caution when you do it yourself.
    1. How To Open A Desktop Hard Drive, Remove The Front Screws: step 1, image 1 of 2 How To Open A Desktop Hard Drive, Remove The Front Screws: step 1, image 2 of 2
      • Use a size 8 Torx screwdriver to remove the front screws. The location and amount may vary depending on your drive, but they are very easy to locate.
      Ask FixBot
    2. How To Open A Desktop Hard Drive, Removing The Hidden Screws: step 2, image 1 of 2 How To Open A Desktop Hard Drive, Removing The Hidden Screws: step 2, image 2 of 2
      • There may be a screw hidden under the front sticker, so make sure to peel it off and check before you open it up. Use a spudger to peel off any material in the way of the screw
      • Please check under the sticker before you open up your disk drive. I didn't, and went full brute-force on the hard drive cover. Whoops!
      Ask FixBot
    3. How To Open A Desktop Hard Drive: step 3, image 1 of 2 How To Open A Desktop Hard Drive: step 3, image 2 of 2
      • Slide a spudger around the front cover to remove any adhesive or rubber insulation before opening.
      Ask FixBot
    4. How To Open A Desktop Hard Drive: step 4, image 1 of 1
      • Gently remove the cover.
      • Do NOT do what I did, please.
      Ask FixBot
    5. How To Open A Desktop Hard Drive: step 5, image 1 of 1
      • There you have it! Now you have a fully-opened hard drive. Whether you want to make a pretty cool (and large) paperweight or perma-delete your data, you can now do so.
      Ask FixBot
This is not a reversible process. I am not responsible for any damage done to you or your hard drive while opening it.
13 other people completed this guide.
Author
with
gamer_Kat
481 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 48
Past 30 Days: 216
All Time: 3,214
