Up to 20% off select tools
Guides
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
010nr
Troubleshooting
A troubleshooting guide for the HP Stream 11-d010nr can be found by clicking here.
Background
The HP Stream 11-d010nr is a low cost laptop released on October 18th, 2015. Internally, it features 2GB of DDR3 RAM, a 2.16GHz Intel Celeron Dual Core N2840 processor, and 32 GB of eMMC storage. The HP Stream 11 is similar in specs to the HP Stream 13, but the HP Stream 11 features an 11.6 inch display with a resolution of 1366 x 768 instead of a 13.3 inch screen. This model has an integrated digital microphone with its webcam as well as dual speakers, a combined audio and microphone jack, and a single USB 2.0 and 3.0 slot.
In terms of physical specs, the HP Stream 11-d010nr weighs 2.6 pounds and has the dimensions of 11.81 in w x 8.10 in d x 0.78 in h. The exterior of the device is mostly plastic, and the device comes in cobalt blue, horizon blue, violet/purple, and orchid magenta.
Identification
The HP Stream 11-d010nr model number is printed directly onto the laptop's bottom case.
Additional Information
HP Stream 11 Customer Support Page
Amazon Reviews for the HP Stream 11
HP Stream Comparison
Author
with
Josh Corrigan
353 Reputation
2 Guides authored
Cal Poly, Team S1-G3, White Winter 2019 Member of Cal Poly, Team S1-G3, White Winter 2019
CPSU-WHITE-W19S1G3
4 Members
60 Guides authored
Past 24 Hours: 4
Past 7 Days: 11
Past 30 Days: 55
All Time: 3,612
