HP Stream 11-d010nr Speaker Replacement
    1. HP Stream 11-d010nr Speaker Replacement, Pry out the inserts: step 1, image 1 of 2 HP Stream 11-d010nr Speaker Replacement, Pry out the inserts: step 1, image 2 of 2
      • Unplug and turn off the HP Stream 11 before disassembling the device.
      • Using a spudger, gently pry off the two elliptical rubber inserts located in the top corners.
      • Carefully remove the two circular rubber inserts positioned beneath the removed elliptical inserts.
      Ask FixBot
    2. HP Stream 11-d010nr Speaker Replacement, Unscrew the back cover: step 2, image 1 of 1
      • Using a Phillips #1 screwdriver, remove the eleven 5.6 mm screws securing the back cover.
      • Keep the screws in a safe place for reassembly.
      Ask FixBot
    3. HP Stream 11-d010nr Speaker Replacement, Pry the keyboard casing up: step 3, image 1 of 2 HP Stream 11-d010nr Speaker Replacement, Pry the keyboard casing up: step 3, image 2 of 2
      • Using an iFixit opening tool, carefully pry open the case to separate the keyboard from the main body. Work slowly to avoid damaging the edges.
      • HP Stream 11s tend to be really difficult to open. If your device is not opening with a standard iFixit opening tool, use a nylon spudger, then the metal spudger, or a metal Jimmy as the last resort.
      • When using the metal spudger or Jimmy, be careful not to bring these tools into contact with any electronic components of the device as this can damage the device.
      Ask FixBot
    4. HP Stream 11-d010nr Speaker Replacement, Identify the connectors: step 4, image 1 of 1
      • Carefully lift the keyboard and identify the three ribbon cables connecting the main body of the laptop to the keyboard.
      • Lift the keyboard with extreme care to avoid damaging the delicate ribbon cables. Applying excessive force can easily tear or break them easily.
      Ask FixBot
    5. HP Stream 11-d010nr Speaker Replacement, Disconnect the cables: step 5, image 1 of 3 HP Stream 11-d010nr Speaker Replacement, Disconnect the cables: step 5, image 2 of 3 HP Stream 11-d010nr Speaker Replacement, Disconnect the cables: step 5, image 3 of 3
      • Using a spudger, gently lift the flaps on the ZIF connectors to release the three ribbon cables securely attached to them.
      • Carefully disconnect the three ribbon cables.
      Ask FixBot
    6. HP Stream 11-d010nr Speaker Replacement, Lift the keyboard out: step 6, image 1 of 1
      • Gently lift the keyboard out of the laptop to fully detach it from the device.
      • While handling, avoid damaging any remaining components.
      Ask FixBot
    1. HP Stream 11-d010nr Speaker Replacement, Speaker: step 7, image 1 of 1
      • Using a Phillips #000 screwdriver, remove the four 3mm screws securing the speaker in place.
      • Keep the screws in a safe location for reuse during the installation of the replacement speaker.
      Ask FixBot
    2. HP Stream 11-d010nr Speaker Replacement: step 8, image 1 of 1
      • Carefully disconnect the wire connecting the speaker to the motherboard.
      • Use tweezers if needed, to avoid damaging the delicate connectors.
      Ask FixBot
    3. HP Stream 11-d010nr Speaker Replacement: step 9, image 1 of 1
      • After disconnecting the speaker from the computer hardware, carefully lift it out of its slot and place it in a safe location.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 423
