HP Stream 11-d010nr Motherboard Replacement
    1. HP Stream 11-d010nr Motherboard Replacement, Pry out the inserts: step 1, image 1 of 2 HP Stream 11-d010nr Motherboard Replacement, Pry out the inserts: step 1, image 2 of 2
      • Unplug and turn off the HP Stream 11 before disassembling the device.
      • Using a spudger, gently pry off the two elliptical rubber inserts located in the top corners.
      • Carefully remove the two circular rubber inserts positioned beneath the removed elliptical inserts.
      Ask FixBot
    2. HP Stream 11-d010nr Motherboard Replacement, Unscrew the back cover: step 2, image 1 of 1
      • Using a Phillips #1 screwdriver, remove the eleven 5.6 mm screws securing the back cover.
      • Keep the screws in a safe place for reassembly.
      Ask FixBot
    3. HP Stream 11-d010nr Motherboard Replacement, Pry the keyboard casing up: step 3, image 1 of 2 HP Stream 11-d010nr Motherboard Replacement, Pry the keyboard casing up: step 3, image 2 of 2
      • Using an iFixit opening tool, carefully pry open the case to separate the keyboard from the main body. Work slowly to avoid damaging the edges.
      • HP Stream 11s tend to be really difficult to open. If your device is not opening with a standard iFixit opening tool, use a nylon spudger, then the metal spudger, or a metal Jimmy as the last resort.
      • When using the metal spudger or Jimmy, be careful not to bring these tools into contact with any electronic components of the device as this can damage the device.
      Ask FixBot
    4. HP Stream 11-d010nr Motherboard Replacement, Identify the connectors: step 4, image 1 of 1
      • Carefully lift the keyboard and identify the three ribbon cables connecting the main body of the laptop to the keyboard.
      • Lift the keyboard with extreme care to avoid damaging the delicate ribbon cables. Applying excessive force can easily tear or break them easily.
      Ask FixBot
    5. HP Stream 11-d010nr Motherboard Replacement, Disconnect the cables: step 5, image 1 of 3 HP Stream 11-d010nr Motherboard Replacement, Disconnect the cables: step 5, image 2 of 3 HP Stream 11-d010nr Motherboard Replacement, Disconnect the cables: step 5, image 3 of 3
      • Using a spudger, gently lift the flaps on the ZIF connectors to release the three ribbon cables securely attached to them.
      • Carefully disconnect the three ribbon cables.
      Ask FixBot
    6. HP Stream 11-d010nr Motherboard Replacement, Lift the keyboard out: step 6, image 1 of 1
      • Gently lift the keyboard out of the laptop to fully detach it from the device.
      • While handling, avoid damaging any remaining components.
      Ask FixBot
    1. HP Stream 11-d010nr Motherboard Replacement, Battery: step 7, image 1 of 1
      • Remove any tape holding the battery connector in place.
      • Using your fingers, carefully unplug the battery.
      Ask FixBot
    2. HP Stream 11-d010nr Motherboard Replacement: step 8, image 1 of 2 HP Stream 11-d010nr Motherboard Replacement: step 8, image 2 of 2
      • Remove the four 3mm #000 Phillips screws holding the battery in place.
      • Carefully lift the battery out of the laptop.
      Ask FixBot
    1. HP Stream 11-d010nr Motherboard Replacement, Motherboard: step 9, image 1 of 1
      • Remove Wi-Fi card from the motherboard.
      Ask FixBot
    2. HP Stream 11-d010nr Motherboard Replacement: step 10, image 1 of 1
      • Use a Phillips #000 screwdriver to remove all 3 mm screws from the motherboard.
      Ask FixBot
    3. HP Stream 11-d010nr Motherboard Replacement: step 11, image 1 of 1
      • Gently lift the ribbon-cable ZIF tabs and remove all 6 cables from the motherboard.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 52
All Time: 1,019
