Battery
2 Answers 3 Score |
What does the blinking light mean? |
2 Answers 2 Score |
Why won't the Dremel won't turn on? |
1 Answer 1 Score |
Why is the battery pack not attaching to the dremel? |
1 Answer 0 Score |
Spanner broken and stuck on dremel |
Documents
Tools
Troubleshooting
For more information regarding common troubleshooting issues, check out the Troubleshooting Page.
Background Information
The Dremel 7300 MiniMite is a basic cheap entry-level rotary tool for mainly light-duty jobs. It's lightweight and small which makes it ideal for high precision jobs, though it shows its lower price point with a nickel cadmium instead of a lithium ion battery and only two speed settings instead of a variable controller.
The main issue most users of this device point to is due to only having a 30 minute battery life and a 3 hour charge time, the up-time on this device will leave you wanting a second battery for longer projects. The device is ideal for trimming nails and sanding or polishing for small projects.
Technical Specifications
Model number: 7300
Voltage rating: 4.8V
No load speed: 6,500-13,000/min
Collet capacities: 1/32, 1/16", 3/32", 1/8"
Charger: 756-01
Charge Time: 3 Hours
Voltage rating: 120 V 60 Hz
Battery pack: 755-01
Battery type: Ni-Cd
Capacity: 200 mA
Item Weight: 1.4 pounds
Length: 8.1 inches
Product Dimensions: 8.1 x 4.4 x 2.6 inches
Accessory change system: Wrench
Origin: USA
Color: Grey
