A basic battery-powered rotary tool Manufactured in 2007 by Dremel.
What does the blinking light mean?
I noticed that the green light is blinking. Is something wrong with the Dremel?
Score 3
1 Comment
What if it never stops blinking??
by
Add a comment
Chosen Solution
Don't worry - The blinking doesn't mean that there is an error. The green LED on the charger indicated that you properly plugged the battery pack into it. While it is charging, it will continue blinking. When charging is complete, the light will stay steady green.
Score 12
7 Comments:
Sweet I was wondering the same thing, thank you interwebs.
by
Same here..........
by
Mine keeps on blinking and when I go to use it, it has no power to operate my Mini Mite
by
Mine blinks when I first put the battery in..5 min later its steady green and of course it is NOT charged. Waiting to hear back from Dremel.
by
I have two lighs. one steady red and other is flasing green float. what does float mean
by
Show 2 more comments
Add a comment
7700/708 battery. green light has been "charging" aka "flashing of 18+ hours and battery is dry as a bone, no charge.
This @#%$#@^ 7700 has LESS than 18 hours of use in 4+ years. Battery is stores away from charger (separate rooms). does the battery just die from being lonely?
1 Comment:
Same issue as @ralph78 and @rroby. Charger LED just keep flashing green. I have two batteries - does the same with both. The flashing seems to be somewhat faster than normal charging indicator. It never goes to steady green (indicating a fully charged battery) and neither battery has any power. I use the dremel infrequently so have always charged a battery before each use. I'm thinking it must be a charger issue rather than a battery problem? Do I need a new charger or have both batteries died?
by
Add a comment
Add your answer
Kat will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 44
Past 30 Days: 148
All Time: 40,910
