Introduction
If you need to replace the collet nut or collet itself, this is the guide for you.
Press the blue button and hold it down.
Unscrew the collet nut, with your fingers (as if you were going to change the bit).
Continue until the collet nut comes completely off of the Dremel.
7 other people completed this guide.
2 Guide Comments
I easily removed the bit by holding the blue button and using the black wrench to loosen it and then I remove the silver piece that holds the bit then when I tried to use another one of the attachments it seems like it’s too large to fit in there I haven’t been able to use any of the other attachments like polishing and the finer little grinders
