Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
OontZ Angle Plus is a water-resistant portable wireless Bluetooth speaker made by Cambridge SoundWorks, an experienced audio manufacturer founded in 1988. OontZ Angle Plus was released in 2014. This model is easy to carry at 6 x 3 x 3 inches. The OontZ Angle PLUS has a battery capacity of 2,200 mAh and a playback time of 15 hours. It can play sound from a device connected via Bluetooth or AUX. The water-resistant feature can only handle gentle water splash, and it is not meant to be submerged in water.
Identification
Most of Oontz plus models are triangle-shaped and are not easy to distinguish from each other. The most observable difference to help identify Oontz Angle Plus 1 from the other models is that the volume, and on and off buttons are located on the top edge of the speaker, whereas in other models you will see these features on the sides. In addition, users can easily identify this model by checking its label underneath the speaker.
Additional information
1) Technical Specs
2) Get-Sale review of Oontz Angle Plus
3) eSouthernGolfZINE review of Oontz Angle Plus
OontZ Angle PLUS User Guide, Version 2.0
Author
with
Artem Nykolenko
203 Reputation
1 Guide authored
USF Tampa, Team 1-1, Nance Spring 2016 Member of USF Tampa, Team 1-1, Nance Spring 2016
USFT-NANCE-S16S1G1
4 Members
72 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 39
All Time: 4,774
