Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
This is a bush pump device page.
The typical feature of this pump is the “Hardwood block” that acts as both, bearing and lever mechanism. The pump is designed that the stand can be directly bolted to the protruding 6” steel casing of the borehole, Ø150 mm NB (Nominal Bore). Three different cylinders are available, the smallest one extend the range to a maximum recommended lift of 80 m. The Bush Pump is not corrosion resistant.
More information: Akvopedia
Author
with
Jake Devincenzi
119,666 Reputation
57 Guides authored
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 47
All Time: 2,706
