Tools
Introduction
Go to step 1 ↓This guide will walk you through the procedure to remove the cylinder from the bottom of the pump, then open it up and replace the foot valve, or check it for wear and tear.
Remove the above grade riser pipe.
Firmly screw a T-handle onto the pump rod.
Use a pipe wrench to loosen and remove the pump spout.
Place the spout on a clean surface to prevent any contamination.
Place one wrench on the top of one of the pump riser plate bolts.
Place another wrench around the bottom of the bolt.
Pull the wrenches apart to loosen the bolt.
