Bush Pump Cylinder (Ndembele) Replacement
  1. Bush Pump Cylinder (Ndembele) Replacement, Head and Handle (Ndembele): step 1, image 1 of 2 Bush Pump Cylinder (Ndembele) Replacement, Head and Handle (Ndembele): step 1, image 2 of 2
    • Linga ukusebenza kwepompo ngokupompa amahlandla ama-40.
    • Ipompo ekungiyo fanele ibuyise nanyana malitha ali-10.
    Ask FixBot
  2. Bush Pump Cylinder (Ndembele) Replacement: step 2, image 1 of 2 Bush Pump Cylinder (Ndembele) Replacement: step 2, image 2 of 2
    • Susa amaphini amabili ahlanganisa isibambo esitjhelelini.
    Ask FixBot
  3. Bush Pump Cylinder (Ndembele) Replacement: step 3, image 1 of 2 Bush Pump Cylinder (Ndembele) Replacement: step 3, image 2 of 2
    • Dosa iimbambo ezimbili zomgqala kude nesitjheleli.
    Ask FixBot
  4. Bush Pump Cylinder (Ndembele) Replacement: step 4, image 1 of 2 Bush Pump Cylinder (Ndembele) Replacement: step 4, image 2 of 2
    • Phakamisa amaphini amabili abambene nesakhelelo sepompo nesibambo siyephezulu, kusukela esakhelweleni sepompo.
    Ask FixBot
  5. Bush Pump Cylinder (Ndembele) Replacement: step 5, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 5, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 5, image 3 of 3
    • Ngokuya ngegadangweli, yenza mbala bona ulekelela isibambo nehloko ngananyana ngezandla ezintathu.
    • Tjhelelisa ibheringhi yentonga ngaphandle kwehloko.
    • Hlola ibheringhi yentonga nehloko ukobana ayikasinyeki nanyana ayikarathuki.
    Ask FixBot
  6. Bush Pump Cylinder (Ndembele) Replacement: step 6, image 1 of 1
    • Susa ihloko nesibambo, uzibeke endaweni ehlwengekileko ukuvimbela ukusilaphazeka.
    Ask FixBot
  7. Bush Pump Cylinder (Ndembele) Replacement, Riser Main Slider (Ndembele): step 7, image 1 of 2 Bush Pump Cylinder (Ndembele) Replacement, Riser Main Slider (Ndembele): step 7, image 2 of 2
    • Ngokuqina phakamisa isikhuphukeli sephayiphu edlulisa amanzi, ngezandla zombili.
    • Thlogomela ukobana ungawisi isikhuphukeli sephayiphu edlulisa amanzi ngombana lokho kungona ipompo nesilinda.
    Ask FixBot
  8. Bush Pump Cylinder (Ndembele) Replacement: step 8, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 8, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 8, image 3 of 3
    • Sebenzisa isipanere sephayiphu ukulenza ligedle ubungaphezulu bephayiphu esikhuphukeleni.
    Ask FixBot
  9. Bush Pump Cylinder (Ndembele) Replacement: step 9, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 9, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 9, image 3 of 3
    • Phakamisa isitjheleli nesikhuphukeli nephayiphu edlulisa amanzi.
    • Beka ipompo nentonga bese uyayiqinisa kuzungeza intonga, uyibophe uyiqinise hlangana nepompo nentonga.
    • Ngokutjheja yehlisa isikhuphukeli nephayiphu edlulisa amanzi nesitjheleli ukuvumela bona izithekghe phezu kwentonga kuqina.
    Ask FixBot
  10. Bush Pump Cylinder (Ndembele) Replacement: step 10, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 10, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 10, image 3 of 3
    • Gedlisa bese ususa zombili ipompo nentonga bese uminyezele endaweni encani ngokungasikinyeki imbumbulu phezu kwesitjheleli.
    Ask FixBot
  11. Bush Pump Cylinder (Ndembele) Replacement: step 11, image 1 of 2 Bush Pump Cylinder (Ndembele) Replacement: step 11, image 2 of 2
    • Susa ingaphezulu lesikhuphukeli sephayiphu edlulisa amanzi, bese uyihlola bona ayikasinyeki nanyana ayikarathuki.
    • Beka isitjheleli endaweni enelanga ukwenzela bona ingasilaphazeki.
    Ask FixBot
  12. Bush Pump Cylinder (Ndembele) Replacement, Above Grade Riser Pipe (Ndembele): step 12, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement, Above Grade Riser Pipe (Ndembele): step 12, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement, Above Grade Riser Pipe (Ndembele): step 12, image 3 of 3
    • Susa ngaphezu kwebanga wesikhuphukeli sephapiphu.
    • Ngokuqinileko krufela isibambo saka-T phezu kwepompo yentonga.
    • Nawujamisela iphayiphu elidlulisa amanzi nesikhuphukeli ngaphezu kwephasi, lisa isibambo se-T sibambelele kufikela ulungele ukufaka esinye isitoki esijamiselako.
    Ask FixBot
  13. Bush Pump Cylinder (Ndembele) Replacement, Spout (Ndembele): step 13, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement, Spout (Ndembele): step 13, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement, Spout (Ndembele): step 13, image 3 of 3
    • Sebenzisa isikrufu sephayiphu ukugedlisa nokususa itjhubhu yepompo
    • Hlola itjhubhu bona ayithikamezeki nanyana isilaphazeke.
    • Beka itjhubhu endaweni ehlwengekileko ukuvimbela ukusilaphazeka.
    Ask FixBot
  14. Bush Pump Cylinder (Ndembele) Replacement, Riser Main (Ndembele): step 14, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement, Riser Main (Ndembele): step 14, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement, Riser Main (Ndembele): step 14, image 3 of 3
    • Beka isikrufu sinye phezu kwepompo yesikhuphukeli sesitja samabowhudu.
    • Beka esinye isikrufu kuzungeza ngaphasi kwebhowudu.
    • Dosa iinkrufu uzihlukanise bona zigedlise amabhowudu.
    • Buyelela isenzekwesi emabhowudwini amathathu aseleko.
    Ask FixBot
  15. Bush Pump Cylinder (Ndembele) Replacement: step 15, image 1 of 2 Bush Pump Cylinder (Ndembele) Replacement: step 15, image 2 of 2
    • Susa iimbumbulu ezine namabhowudu avikele isikhuphukeli sepompo sesitja uzibeke esiphathweni esibona ilanga esinjenge bakhede.
    Ask FixBot
  16. Bush Pump Cylinder (Ndembele) Replacement: step 16, image 1 of 2 Bush Pump Cylinder (Ndembele) Replacement: step 16, image 2 of 2
    • Zungezisa isitja sepompo amadigri ama-45. Lokho kuzokwenzelela ukubamba okuncono nawuphakamisa isitja.
    Ask FixBot
  17. Bush Pump Cylinder (Ndembele) Replacement: step 17, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 17, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 17, image 3 of 3
    • Ngokuvikela phakamisa isibambo se-T amanungu ambalwa.
    • Lokhana abantu ababili basekela isibambo se-T, susa ipompo yentonga.
    • Yehlisa isibambo se-T ngokusihlenga ipompo yentonga ikwazi ukuzijamele.
    Ask FixBot
  18. Bush Pump Cylinder (Ndembele) Replacement: step 18, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 18, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 18, image 3 of 3
    • Umhlobo lo wepompo usebenzisa ipoto yennyawo ezintathu nesivimbo noku tjhewa ukuphakamisa isikhuphukeli sephayiphu edlulisa amanzi. Isikrufu se-C singasebenziswa ukuphakamisa isikhuphukeli sephayiphu edlulisa amanzi.
    • Ngokuvikela bamba bese uqinise isikhuphula phayiphu esikhuphukeleni sephayiphu edlulisa amanzi ngaphasi kwetjhuba letjhubhu.
    Ask FixBot
  19. Bush Pump Cylinder (Ndembele) Replacement: step 19, image 1 of 2 Bush Pump Cylinder (Ndembele) Replacement: step 19, image 2 of 2
    • Ngokutjheja ungaphunyukelwa yintambo, sebenzisa isivimbo netjhewa ukuphakamisa isikhuphukeli sephayiphu edlulisa amanzi kufikela isikhuphula phayiphu sifikelele isivimbo netjhewa.
    Ask FixBot
  20. Bush Pump Cylinder (Ndembele) Replacement: step 20, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 20, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 20, image 3 of 3
    • Na isikhuphukeli sephayiphu edlulisa amanzi sifikelele isivimbo netjhewa, vikela ingaphasi bese uqinise hlangana nesikhuphukeli sephayiphu edlulisa amanzi.
    Ask FixBot
  21. Bush Pump Cylinder (Ndembele) Replacement: step 21, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 21, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 21, image 3 of 3
    • Vikela umphasi ngokuqinisa esakhelelweni esiphasi usebenzise ibhowudu.
    • Ibhowudu yinye yanele ukubamba umphasi ukuqinisa umphakathi, ungangeza ngenye ibhowudu nawufuna ukuyiqinisa.
    Ask FixBot
  22. Bush Pump Cylinder (Ndembele) Replacement: step 22, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 22, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 22, image 3 of 3
    • Nawusasekela umphezulu we phayiphu, ngokutjheja khambisa isikhuphula kuqinisa kude nephayiphu.
    • Yehlisa isikhuphula kuqinasa bese ugedlisa ukuya ehlabathini ukuvimbela iintambo bona zirarane esivimbweni netjheweni.
    Ask FixBot
  23. Bush Pump Cylinder (Ndembele) Replacement: step 23, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 23, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 23, image 3 of 3
    • Bambanisa isikhuphula kuqinisa esikhuphukeleni sephayiphu edlulisa amanzi eduze naphasi ngokukghonekako.
    Ask FixBot
  24. Bush Pump Cylinder (Ndembele) Replacement: step 24, image 1 of 2 Bush Pump Cylinder (Ndembele) Replacement: step 24, image 2 of 2
    • Na isikhuphula kuqinisa siqinileko, yenza ukugedla entambeni.
    • Nawugedlisa iintambo usekela isikhuphukeli, gedlisa umphasi kuqinisa.
    Ask FixBot
  25. Bush Pump Cylinder (Ndembele) Replacement: step 25, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 25, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 25, image 3 of 3
    • Sebenzisa intambo ukudosa isikhuphukeli sephayiphu edlulisa amanzi phezulu kabuthaka.
    • Ynza mbala bona intambo ihlangana nepoto yennyawo ezintathu ukuvikela ipoto yennyawo ezintathu ingaweli phasi.
    • Qala umphezulu wepoto yennyawo ezintathu bona ulinganele nesikhuphukeli sephayiphu edlulisa amanzi bona ibe seskhaleni esisekelako.
    Ask FixBot
  26. Bush Pump Cylinder (Ndembele) Replacement: step 26, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 26, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 26, image 3 of 3
    • Susa ukuqinisa esikhuphukeleni sephayiphu edlulisa amanzi bese ubuyelela amagadango ama-23 ukuya kwama-25 kufikela isihlanganisi sembuke.
    Ask FixBot
  27. Bush Pump Cylinder (Ndembele) Replacement: step 27, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 27, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 27, image 3 of 3
    • Na isihlanganisi sokuthoma siveziwe, qinisa umphasi ngaphasi kwesihlanganisi.
    Ask FixBot
  28. Bush Pump Cylinder (Ndembele) Replacement: step 28, image 1 of 1
    • Susa isikhuphula kuqinisa ukusuka esikhuphukeleni sephayiphu esidlulisa amanzi bese uvikela epotweni yennyawo ezintathu ukuyisusa endleleni.
    Ask FixBot
  29. Bush Pump Cylinder (Ndembele) Replacement: step 29, image 1 of 2 Bush Pump Cylinder (Ndembele) Replacement: step 29, image 2 of 2
    • Phatha isikrufu sephayiphu amanungu ambalwa ngaphezu kwesihlanganisi egadangweneli.
    • Usebenzisa isikrufu sephayiphu, uyasikrufulula esigabeni sokuthoma sesikhuphukeli phayiphu edlulisa amanzi ehlanganweni.
    Ask FixBot
  30. Bush Pump Cylinder (Ndembele) Replacement: step 30, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 30, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 30, image 3 of 3
    • Vikela ipetjhe yegadi phezu kwesihlanganisi ukuvikela amanzi bona arhatjheke na innhlanganisi zehlukanisiweko.
    • Usebenzisa isikrufu sepompo, gedlisa isikhuphukeli sephayiphu edlulisa amanzi fikela amanzi athome ukuthulukela ngaphakathi kwepetjhe yegadi.
    • Unga gedlisi kuya phambili kufikela amanzi ajame ukuphuma.
    Ask FixBot
  31. Bush Pump Cylinder (Ndembele) Replacement: step 31, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 31, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 31, image 3 of 3
    • Susa ipetjhe yegadi bese uqedelela ukugedlisa isikhuphukeli sephayiphu edlulisa amanzi.
    • Susa isigaba sokuthoma sesikhuphukeli sephayiphu edlulisa amanzi ngokuyiphakamisa ijame ilinganisele, bese usekela umphezulu wesigaba bese ubeka ipompo uyisekele esikhaleni phezulu kwepoto yennyawo ezintathu.
    Ask FixBot
  32. Bush Pump Cylinder (Ndembele) Replacement: step 32, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 32, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 32, image 3 of 3
    • Bambanisa bese uqinisa intonga amanungu ambalwa ngaphasi kwentonga yepompo yokuthoma ebambeneko.
    Ask FixBot
  33. Bush Pump Cylinder (Ndembele) Replacement: step 33, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 33, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 33, image 3 of 3
    • Usebenzisa inkrufu ze-C, krufulula intonga yepompo engcenyeni eseleko.
    • Na isihlanganisi sahlukeneko, ngokutjheja yehlisa isikhuphukeli sephayiphu edlulisa amanzi ehlabathini.
    Ask FixBot
  34. Bush Pump Cylinder (Ndembele) Replacement: step 34, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 34, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 34, image 3 of 3
    • Ngokutjheja yehlisa isikhuphukeli sephayiphu, ukuyaphezulu, bese ubeka endaweni enelanga, kuhle uyisame ngaphezu kwehlabathi, ukuvikela ukusilaphazeka.
    Ask FixBot
  35. Bush Pump Cylinder (Ndembele) Replacement: step 35, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 35, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 35, image 3 of 3
    • Susa isibambo se-T kusuka epompeni yentonga ehlukanisiweko.
    • Bambanisa isibambo se-T epompeni yentonga eseleko.
    • Susa intonga eqinileko bese ubuyelela amagadango ama-29 ukuya kwama-35 fikela isikhuphukeli sephayiphu edlulisa amanzi sisuke soke, nanyana isigaba esaphukileko sifikelelwe.
    Ask FixBot
  36. Bush Pump Cylinder (Ndembele) Replacement, Cylinder (Ndembele): step 36, image 1 of 1
    • Tjheja bona ubeka isilinda kude nehlabathi ukobana ingasinyeki nanyana isilaphazeke.
    Ask FixBot
  37. Bush Pump Cylinder (Ndembele) Replacement: step 37, image 1 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 37, image 2 of 3 Bush Pump Cylinder (Ndembele) Replacement: step 37, image 3 of 3
    • Usebenzisa amabhowudu wamaphayiphu amabili, skrufulula isilinda esikhuphukeni sephayiphu edlulisa amanzi.
    Ask FixBot
  38. Bush Pump Cylinder (Ndembele) Replacement: step 38, image 1 of 2 Bush Pump Cylinder (Ndembele) Replacement: step 38, image 2 of 2
    • Buthaka dosa isilinda esuka epompeni yentonga bese ulisa ivelifu ekhambako nevelifu yenyawo.
    Ask FixBot
Ukubuyisela into oyenzele ihloso ethileko, landela ifundiso ngendlela ethoma samva.
iRobot
1 Reputation
636 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 24
All Time: 454
