Float Gasket
1 Answer 0 Score |
Leaking from the bottom |
No Answers 0 Score |
Why does my spot cleaner shut down after 10 minutes |
Documents
Tools
Troubleshooting
If you are having issues with your Bissell SpotClean ProHeat 5207U and need additional help, here is the troubleshooting page.
Background
The Bissell SpotClean ProHeat is a high-tech cleaning device used to pick up dirt, get rid of stains and remove deeply set dirt stains. It was released in 2022 as a new and improved cleaning device provided by Bissell. The Bissell SpotClean is based in America and does not partake in international shipping however a 3rd party source such as amazon can sell It internationally. The SpotClean ProHeat is sold for about $115 a product. The product itself is meant for a suburban type of lifestyle.
This specific model has not made the news however Bissell has been making one of the best carpet cleaning machines since 1979 according to surveys. Bissell has had to recall over 60,000 units for the Bissell cordless multi-surface wet dry vacuum. This was due to battery management which gave risk to fires within the device. This specific model is typically liked with complimentary reviews with an average rating of 4.2 stars.
Bissell is widely known for its cleaning technology so the SpotClean ProHeat is one of many of their devices. Research says it's unclear which model came before the SpotClean ProHeat however the original device is the Bissell Little Green. The Bissell ProHeat 2x is supposed to be a more powerful version of the SpotClean ProHeat as it is the newer model of the Bissell ProHeat 2.
Identification
The easiest way to ensure you have the right model is by checking the manual or information located on the box. To properly identify your device, you need to find the model and/or serial number printed on a label which is usually located on the back or on the base of the unit. On lift-off models the way to identify your device is by removing the lift-off tank and locating the printed label with the device number.
Technical Specifications
Name: Bissel SpotClean® ProHeat® Portable Carpet Cleaner
Model No 5207U
Similar models 5207F 52069, 5207, 52071, 52072, 52073, 52077, 52079, 5207P, 5207R, 5207T, 5207U, 82072
Power:
Power ratings : 3 amps
Power source: corded
Power cord length: 15’
Hose length: 4.5’
Dirt Collection:
Surface Type: Stairs, Carpet, Auto
Clean Tank Capacity 37oz
Specialty Tools:
Stain Tools: 3 in Tough Stain Tool
Other specs
Color: Motely Blue With Light Smokey Blue Accents
Carry Handle: Yes
Weight 8.5 lbs
Additional Information
Bissell SpotClean ProHeat 5207 Support Page
Bissell SpotClean ProHeat 5207 User manual
Bissell SpotClean ProHeat 5207 Review
Bissell Carpet Cleaner Comparison Chart
