Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement
  1. Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement, Spraying Mechanism: step 1, image 1 of 3 Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement, Spraying Mechanism: step 1, image 2 of 3 Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement, Spraying Mechanism: step 1, image 3 of 3
    • Place the brush in front of you and make sure that the brushes are rotated towards the ceiling.
    • Separate the brush from the hose by pressing the lever.
    Ask FixBot
  2. Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement: step 2, image 1 of 3 Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement: step 2, image 2 of 3 Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement: step 2, image 3 of 3
    • Using a Phillips screwdriver, unscrew the two 12.8 mm screws on the lever cap.
    • Remove the cap on top of the spring mechanism.
    Ask FixBot
  3. Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement: step 3, image 1 of 3 Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement: step 3, image 2 of 3 Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement: step 3, image 3 of 3
    • Grab the spraying mechanism and separate it from the lever by pulling it back.
    • Rotate the spraying mechanism clockwise to fully separate it.
    Ask FixBot
  4. Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement: step 4, image 1 of 3 Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement: step 4, image 2 of 3 Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement: step 4, image 3 of 3
    • Grab the spring mechanism and pull back to fully loosen it.
    Ask FixBot
  5. Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement: step 5, image 1 of 3 Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement: step 5, image 2 of 3 Bissell SpotClean ProHeat 5207U Spraying Mechanism Replacement: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Using tweezers, squeeze the hose clamp prongs together to loosen it.
    • As you are squeezing the hose clamp prongs, pull the spraying mechanism out to remove it.
    • Once the spraying mechanism is removed, and squeeze the clamp prongs again and install the new mechanism.
    Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 31
All Time: 330
