Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Bed Head Curlipops hair curler is a go-to styling tool for anyone who wants big, bouncy curls or relaxed, beachy waves without the hassle. Its wand-style design skips the traditional clamp, making it easy to wrap your hair around and style from root to tip. This line also provides a range of barrel sizes and shapes.
This device released in 2023 and is still available today for purchasing. The price varies from different suppliers which sell this product, but typically the price is within a 30-40 dollar range.
It uses Tourmaline Ceramic Technology, which helps keep your hair smooth and shiny while reducing frizz and preventing heat damage. The curler heats up to 400°F and stays consistently hot while you style, so you don’t have to keep waiting for it to catch up.
It also comes with a heat-protective glove (so you don’t burn your fingers) and works with dual voltage, which is perfect if you travel a lot.
Identification
The Bed Head Curlipops Hair Curler is a hair styling tool designed to curl hair with maximum efficiency. The barrel of the curling iron has warped, spiral like casing that houses the heater, intended for easy curling. There is a power button which lights up upon being switched located on the handle, paired with a tip of the curling iron housed in plastic, which helps the user to not burn their fingers. Located on the back side of the handle is the model number. The Bed Head Curlipops Hair Curler comes in a variety of bright metallic colors, most dominantly, Purple and Green. The iron also includes a long black cord for electric input.
Technical Information
Curlipops Wand:
  • Barrel Size: ¾ inch ​Link
  • Dimensions: 15.8 x 2.2 x 2.2 inches
  • Weight: 1.1lbs
  • Technology: Tourmaline Ceramic for reduced frizz and enhanced shine​
  • Design: Clamp-free wrap-and-go​
  • Maximum Heat: Up to 400°F​
  • Dual Voltage: Suitable for worldwide use​
  • Additional Features: Includes a heat-protective glove​
  • Heat Settings:
    • Maximum Temperature: Heats up to 400°F, suitable for various hair types and textures.​
    • Heat Recovery: Rapid heat recovery system maintains consistent temperature during styling.​
  • Safety and Convenience Features:
    • Dual Voltage: Equipped with dual voltage capability, making it suitable for worldwide use.​
    • Heat Protective Glove: Includes a bonus heat-protective glove to ensure safe styling.​
    • Swivel Cord: Features a tangle-free swivel cord for ease of use during styling sessions.
    • Color: Typically available in a vibrant green hue.​
Additional Information
Author
with
Landon Pinto
649 Reputation
4 Guides authored
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 56
All Time: 690
