Bed Head Curlipops Heating Element Replacement
    1. Bed Head Curlipops Heating Element Replacement, Handle Casing: step 1, image 1 of 1
      • Remove all four of the 4 mm Phillips screws on either side of the casing.
      Ask FixBot
    2. Bed Head Curlipops Heating Element Replacement: step 2, image 1 of 1
      • Using an opening tool, insert it along the seam where both halves of the casing meet, and slowly pry the left side of the casing from the right.
      • Gently pull back the right side of the casing from the center molding.
      Ask FixBot
    1. Bed Head Curlipops Heating Element Replacement, On Switch: step 3, image 1 of 1
      • Move wiring or other components away from the main soldering field.
      Ask FixBot
    2. Bed Head Curlipops Heating Element Replacement: step 4, image 1 of 2 Bed Head Curlipops Heating Element Replacement: step 4, image 2 of 2
      • Release the securing tabs on the switch to the center molding.
      • Use a 4mm flat head screwdriver to break off the solder where the wires meet the switch.
      Ask FixBot
    3. Bed Head Curlipops Heating Element Replacement: step 5, image 1 of 1
      • Press the new switch back into the center molding and use a soldering iron to solder the wires on the new switch.
      Ask FixBot
    1. Bed Head Curlipops Heating Element Replacement, Heating Element: step 6, image 1 of 2 Bed Head Curlipops Heating Element Replacement, Heating Element: step 6, image 2 of 2
      • Remove the four 4 mm Phillips screws shown on the heating element housing.
      • Pull back on the heater housing to release it from the main handle molding.
      Ask FixBot
    2. Bed Head Curlipops Heating Element Replacement: step 7, image 1 of 2 Bed Head Curlipops Heating Element Replacement: step 7, image 2 of 2
      • Locate the wiring of the heating element on the switch.
      • Remove the solder from both wires.
      • Once both wires are released, pull back on the heating element to release it from the assembly.
      Ask FixBot
    3. Bed Head Curlipops Heating Element Replacement: step 8, image 1 of 1
      • Use a soldering iron to reconnect the heating element wires to the metal tabs on the switch.
      Ask FixBot
Landon Pinto
649 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 30
All Time: 219
