Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Apple IIc was developed as Apple's first take on the portable computer; the c in IIc stands for compact. It was designed to be marketable to first-time users who had no technical or computer background. Although the computer itself was fairly portable, it took a few years before the monitor and other equipment could be moved as easily.
Identification
The Apple IIc is easily identified by the IIc marked on the top right corner of the device and the volume knob on the left underside of the computer. Its successors would have a different model listed and no volume knob.
Additional Information
Reactive Micro Apple IIc v4 ROM Upgrade Installation Guide
Apple Service Technical Procedures Apple II Family Volume One
Peripheral Interface Guide: Service Technical Procedures
Apple Monochrome Monitor and Monitor IIe Product Brochure
Apple IIc Memory Expansion Card Reference Manual
Apple IIc Technical Reference Manual
Apple IIc to NEC 2015 Spinwriter Cable Technical Note
Apple Super Serial Card: Apple IIc Equivalents (12/96) Tech Info Library Article
Apple IIc: Defeating the Keyboard's Repeat Function — Tech Info Library Article
Apple IIc Serial Port Cable Pinouts to ImageWriter II and APM
Apple II Monochrome Monitors Specifications (Discontinued)
Apple IIc Pinouts for External Disk Port
Apple IIc Video Expansion Port Description
Apple IIc Cable Structure to Lex Modem Tech Info Library Article
Apple IIc Hardware Port Pin Assignments
Apple IIc Pinouts and Switch Settings to Hayes Modem
Apple IIc Serial Port Interfacing (1 of 2) Tech Info Library Article
Apple IIc: Cable Structure to Okidata 92 Serial Adapter — Tech Info Library Article
Apple IIc Cable Structure to Comrex CR-II — Tech Info Library Article
Apple IIc Technical Procedures Erratum for New or Upgraded ROM Systems
Apple Technical Procedures Volume Five
Apple Service Technical Procedures Apple II Family Volume Two
Apple Monitor IIc User's Manual
Author
with
Josiah
658 Reputation
3 Guides authored
Cal Poly, Team 21-23, Maness Fall 2011 Member of Cal Poly, Team 21-23, Maness Fall 2011
CPSU-MANESS-F11S21G23
4 Members
72 Guides authored
Past 24 Hours: 6
Past 7 Days: 26
Past 30 Days: 105
All Time: 23,653
