Up to 20% off select tools
Apple IIc Keyboard Replacement
Views: 4.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
105
All Time:
4,417
Comments: 1
1 comment on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 8
8 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 7 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Replacing the keyboard is an easy repair that is unfortunately necessary in certain cases. This guide will take you through the process of removing your keyboard step by step.
    1. Apple IIc Keyboard Replacement, Disassembling Apple IIc Cover: step 1, image 1 of 2 Apple IIc Keyboard Replacement, Disassembling Apple IIc Cover: step 1, image 2 of 2
      • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
      Ask FixBot
    2. Apple IIc Keyboard Replacement: step 2, image 1 of 2 Apple IIc Keyboard Replacement: step 2, image 2 of 2
      • Release the catch by pushing it in using a plastic opening tool.
      • The catch is off-center, but in line with the middle of the speaker underneath.
      Ask FixBot
    3. Apple IIc Keyboard Replacement: step 3, image 1 of 2 Apple IIc Keyboard Replacement: step 3, image 2 of 2
      • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
      Ask FixBot
    4. Apple IIc Keyboard Replacement: step 4, image 1 of 2 Apple IIc Keyboard Replacement: step 4, image 2 of 2
      • Lift the handle straight up to remove.
      Ask FixBot
    1. Apple IIc Keyboard Replacement, Keyboard: step 5, image 1 of 2 Apple IIc Keyboard Replacement, Keyboard: step 5, image 2 of 2
      • Tilt the keyboard up while detaching the ribbon connection by pulling it straight up. You may have to wiggle the connector sideways to loosen it.
      • Be careful not to force the ribbon while pulling it out to avoid tearing. Do not try to pull the ribbon out by pulling the keyboard as it may cause tearing.
      Ask FixBot
4 other people completed this guide.
Author
with
Alexandria Weinberg
601 Reputation
3 Guides authored
Cal Poly, Team 21-23, Maness Fall 2011 Member of Cal Poly, Team 21-23, Maness Fall 2011
CPSU-MANESS-F11S21G23
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 105
All Time: 4,417
