Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Acer Chromebook 315, released in late 2022, is part of a series of laptops produced by Acer that utilize ChromeOS as an operating system. ChromeOS-based laptops or "Chromebooks" are known for being very affordable, simple, lightweight and easy to use. This makes them very popular for use in schools and other educational institutions. In particular, the Acer Chromebook CB315-3HT-C3FQ features a very compact design which can easily fit into a schoolbag, while still retaining a screen size of 15.6 inches.
The Acer Chromebook has entry-level hardware, such as 4GB of LPDDR4 Ram and an Intel Celeron n4020 dual-core processor. these give an adequate performance for simple web-based tasks and multitasking, but not much more than that. It features 2 USB 3.0 ports, as well as 2 Micro-USB ports. However, there is no ethernet cable, which means to use your chromebook you will need to have a wireless internet connection (WiFi). The Acer Chromebook 315 has a battery life of ~12.5 hours, which is plenty of time needed to get through a school day where this would typically be used.
Identification
Distinguishing the Chromebook from other Acer Chromebooks in the CB315-3H series is fairly easy-- simply look for the model number on the back of the Chromebook, it should say "CB315-3HT-C3FQ".
Technical Specifications
General
  • Operating System: ChromeOS
  • Manufacturer: Acer
Processor
Manufacturer: Intel®
Model: N4020
Type: Celeron®
Processor Speed: 1.10 GHz
Processor Core: Dual-core (2 Core™)
vPro Technology: No
Display & Graphics
Graphics Controller Manufacturer: Intel®
Graphics Controller Model: UHD Graphics
Graphics Memory Accessibility: Shared
Screen Size:15.6"
Display Screen Type: LCD
Display Screen Technology:
  • In-plane Switching (IPS) Technology
  • ComfyView (Matte)
Backlight Technology: LED
Touchscreen: Yes
Multi-touch Screen: Yes
Screen Resolution: 1920 x 1080
Standard Refresh Rate: 60 Hz
Memory
Total Installed System Memory:4 GB
System Memory Technology: LPDDR4
Memory Card Reader: No
Storage
Flash Memory Capacity: 64 GB
Network & Communication
Wireless LAN Standard: IEEE 802.11ac
Ethernet Technology: Gigabit Ethernet
Bluetooth Standard: Bluetooth 5.0
Built-in Devices
Front Camera/Webcam Video Resolution: 1280 x 720
Microphone: Yes
Finger Print Reader: No
Number of Speakers: 2
Sound Mode: Stereo
Interfaces/Ports
Number of USB 3.0 Ports: 2
Number of USB 3.1 Gen 1 Type-C Ports: 2
Total Number of USB Ports: 4
USB Type-C: Yes
USB Type-C Detail
  • USB Type-C Port Supporting: USB 3.1 Gen 1 (up to 5 Gbps), DisplayPort over USB-C, USB charging 5 V; 3 A, DC-in port 5 or 9 or 15 or 20 V; 45 W
Input Devices
Pointing Device Type: TouchPad
Keyboard: Yes
TouchPad Features: Moisture Resistant
Battery Information
Number of Cells: 3-cell
Battery Chemistry: Lithium Polymer (Li-Polymer)
Maximum Battery Run Time: 12.50 Hours
Power Description
Maximum Power Supply Wattage: 45 W
Physical Characteristics
Height: 0.80"
Width: 14.4"
Depth: 9.9"
Weight (Approximate): 3.59 lbs
Product Color: Silver
Additional Information
Acer Chromebook 315 CB315-3HR-C3FQ Product Page
Acer Chromebook CB315-3H Product Review
Acer Chromebook 315 User Manual
Author
with
Kyle
342 Reputation
3 Guides authored
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 88
All Time: 2,415
