Acer Chromebook CB315-3HT-C3FQ Back Panel Replacement
  1. Acer Chromebook CB315-3HT-C3FQ Back Panel Replacement, Back Panel: step 1, image 1 of 1
    • Flip the Chromebook over so the bottom is facing up.
    Ask FixBot
  2. Acer Chromebook CB315-3HT-C3FQ Back Panel Replacement: step 2, image 1 of 1
    • Remove all 10 screws that hold the bottom panel in place using a Phillips #1 screwdriver.
    Ask FixBot
  3. Acer Chromebook CB315-3HT-C3FQ Back Panel Replacement: step 3, image 1 of 2 Acer Chromebook CB315-3HT-C3FQ Back Panel Replacement: step 3, image 2 of 2
    • Use an iFixit opening tool to pry the bottom panel up and detach it from the rest of the Chromebook.
    Ask FixBot
  4. Acer Chromebook CB315-3HT-C3FQ Back Panel Replacement: step 4, image 1 of 2 Acer Chromebook CB315-3HT-C3FQ Back Panel Replacement: step 4, image 2 of 2
    • Always wear an anti-static wrist strap when working with an electronic device, as static electricity from your hand could damage it.
    • To use the anti-static strap, attach the strap to your wrist and then attach the end of the cord to something that is also metal, preferably something in your Chromebook. This strap will discharge any static electricity that you build up instead of it going into the metal parts of your computer, which could damage the components.
    Ask FixBot
Ethan Sylvia
372 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 33
All Time: 573
