Solor/wireless KB will not charge
I have two that are not working. I have put them under light and in sun light but no charge. Can the solor batteries be replaced?
Yes, the batteries can be replaced. Since these keyboards are quite old, the batteries may have simply reached the end of their life. I'd check the battery type and availability before taking it apart.
And how would anyone know battery type and availability if not disassembled to identify a battery pack with markings to shop for a replacement?
Hi!
I think this keyboard only uses a coin cell battery (ML2032 or LIR2032) which you can replace using this guide: Logitech K750 Keyboard Battery Replacement.
Make sure that you are replacing the battery with a rechargeable battery, you can use a ML2032 or a LIR2032 coin cell battery. Do not use a standard CR2032 as it is not rechargeable.
Good luck,
Cheers
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 36
All Time: 36
