Up to 20% off select tools
Logitech K750 Keyboard Battery Replacement
Views: 293K
View statistics:
Past 24 Hours:
41
Past 7 Days:
309
Past 30 Days:
1,420
All Time:
293,044
Comments: 126
31 comments on steps, 95 guide comments.
Go to guide comments
Completed: 213
213 people have marked this guide "completed." Will you be next?
Favorites: 10
10 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 15 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Logitech
Logitech and iFixit are working together to help people repair their Logitech devices.
Parts
Tools
  • Spudger
    4.9
  • Flat head Screwdriver
    $1.99 $6.99
    4.7
    Optional
Introduction
Go to step 1 ↓
Use this guide to safely remove and replace the battery in a Logitech K750 Solar wireless keyboard.
Note: The K750 Solar requires a rechargeable ML2032 coin cell battery as a replacement. Although it's the same size and shape as the more common CR2032, CR2032s are not rechargeable. You can also use a LIR2032 rechargeable battery as well.
    1. Logitech K750 Keyboard Battery Replacement, Turn off the keyboard: step 1, image 1 of 1
      • Before you begin, flip the keyboard's power switch into the OFF position.
      Ask FixBot
    2. Logitech K750 Keyboard Battery Replacement, Flip the keyboard over: step 2, image 1 of 2 Logitech K750 Keyboard Battery Replacement, Flip the keyboard over: step 2, image 2 of 2
      • Flip the entire keyboard over, keys facing down.
      Ask FixBot
    3. Logitech K750 Keyboard Battery Replacement, Pry open the battery tray: step 3, image 1 of 3 Logitech K750 Keyboard Battery Replacement, Pry open the battery tray: step 3, image 2 of 3 Logitech K750 Keyboard Battery Replacement, Pry open the battery tray: step 3, image 3 of 3
      • The ML2032 rechargeable coin cell battery is located in a tray at the back edge of the keyboard.
      • Insert the flat end of a spudger into the gap between the battery tray and the top surface of the keyboard.
      • Pivot the spudger down, towards the top of the keyboard, to begin to pry the tray out of its cavity.
      Ask FixBot
    4. Logitech K750 Keyboard Battery Replacement, Remove the battery tray: step 4, image 1 of 3 Logitech K750 Keyboard Battery Replacement, Remove the battery tray: step 4, image 2 of 3 Logitech K750 Keyboard Battery Replacement, Remove the battery tray: step 4, image 3 of 3
      • Use the flat end of the spudger to push the battery tray out and away from the keyboard.
      • The tray is held in by small "ears" and may take a significant amount of force to dislodge.
      • If you're having trouble, use the end of a spudger or a flat blade screwdriver to "walk" the tray out, pushing on alternating sides instead of directly in the middle.
      • Remove the battery tray.
      • During reassembly, firmly push the battery tray into its slot until it clicks into place.
      Ask FixBot
    5. Logitech K750 Keyboard Battery Replacement, Remove the battery: step 5, image 1 of 3 Logitech K750 Keyboard Battery Replacement, Remove the battery: step 5, image 2 of 3 Logitech K750 Keyboard Battery Replacement, Remove the battery: step 5, image 3 of 3
      • Push the battery out of the tray to remove it.
      • Note the battery orientation—it can only go in one way. Set the battery into the tray with side with the text and the "+" sign facing down.
      • Use only a rechargeable ML2032 coin cell battery as a replacement. Although it's the same size and shape as the more common CR2032, CR2032s are not rechargeable.
      Ask FixBot
213 other people completed this guide.
Author
with
Carsten Frauenheim
175,088 Reputation
442 Guides authored
95 Guide Comments
Thank you. Worked perfectly. Gained trust in this site. Lost respect for Logitech.
henry - Reply Share
My sentiments, exactly!
Melinda Mcvay - Reply Share
There a better way to open it
put the knife or better a screwdriver on the other side (keys upside); worked for me without damage the keyboard :D
yannick NR - Reply Share
Thank You! That did work much better!
Matt Anderson - Reply Share
Here is an even better method.
You can also totally prevent damage by finding a laminated biz card and cutting it into 2 one inch strips and inserting both of them into the slot on the top side (solar side) of the battery compartment.
Then get your tool ( I like small pointed scissors) and pry it out between the cards.
Very easy!
David Powers - Reply Share
Past 24 Hours: 41
Past 7 Days: 309
Past 30 Days: 1,420
All Time: 293,044
