Up to 20% off select tools
Repair, disassembly, and troubleshooting information for the iPhone 15 Pro Max, Apple's top-of-the-line flagship smartphone, released September 22nd, 2023. It features a 6.7" ProMotion OLED display, a triple-lens rear camera system with a new 5x optical zoom periscope, and 5G. Successor to the iPhone 14 Pro Max.
iPhone issue restarts randomly
Hi,
Iphone restarts randomly, sometimes it goes a day without being restarted but sometimes 7-8 times in a row, from what i've seen mostly it happens when am charging it like at low battery under 20%, it gets hot and it restarts, sometimes just happens randomly, even it enters diagnostics mode, i already have sent it to many repair shops and yet still the same issue, as far as i know they already have tested changing the face id flex, earpiece / sensor flex. This is the same panic log i always get
{"bug_type":"210","timestamp":"2026-11-01 11:46:56.00 +0100","os_version":"iPhone OS 27.0.1 (24A446)","roots_installed":0,"incident_id":"B81BA5E7-6A24-4D05-BBB8-D443A61539D9"}
"crashReporterKey" : "0d6e2b0dc0120a65f12605d990f8386a3bdafdfc",
"panicProcessingFlags" : "0x0",
"product" : "iPhone16,2",
"kernel" : "Darwin Kernel Version 27.0.0: Thu Aug 13 21:40:21 PDT 2026; root:xnu-13432.2.10~2\/RELEASE_ARM64_T8122",
"socRevision" : "11",
"panicString" : "panic(cpu 0 caller 0xfffffff04dd87634): \"i2c2::_checkBusStatus Bus is still in a bad state; last read status 00010118 int shadow 00010100 xfer 00000000 fifo 00000000 for device audio-speaker-top\" "socId" : "8130",
"date" : "2026-11-01 11:46:56.97 +0100",
"panicFlags" : "0x802",
"codeSigningMonitor" : 2,
"incident" : "B81BA5E7-6A24-4D05-BBB8-D443A61539D9",
"build" : "iPhone OS 27.0.1 (24A446)",
"bug_type" : "210",
"roots_installed" : 0,
"trmStatus" : 1,
"otherString" : "\n** Stackshot Succeeded Bytes Traced 342770 (Uncompressed 808000) \n",
"panicProcessingInfo" : "Panic Timing info: (timing: Panic info created, timestamp: 81202681986) ",
"PanicLogUtilizationMetrics" : {"PercentUsed":42,"PanicRegionSizeInBytes":835528,"UsedSizeInBytes":353454,"StackshotLengthInBytes":342770,"OtherLogLengthInBytes":72,"PanicLogLengthInBytes":9795},
"embeddedPanicHeaderVersion" : "9",
"panicTimeInSecsAndUsecs" : "wall 1793529990 s 486672 us",
"bootProgressRegister" : "0x2080000c",
"repairStatus" : "1",
Score 1
Add a comment
1 Answer
Root‑Cause Confidence: Medium‑High – the panic originates from the I²C‑2 bus controller failing to clear a bad state on the audio‑speaker‑top device.
Common Faulty Components
- I²C‑2 controller (T8122 SOC)
- Audio‑speaker‑top codec (codec 0x22)
- PP_VCC_MAIN rail to the codec
- J6400 pin‑pair (SCL/SDA) routing to the speaker module
- Bus‑level pull‑up resistors (R = 2.2 kΩ typ.)
Repair Recommendation
- Replace the audio‑speaker‑top codec assembly or, if unavailable, re‑populate the I²C‑2 controller pins; board‑level repair is high‑risk.
Rsults by BIM TECH Panic-Full AI Analyer
Add a comment
Add your answer
Yll Hasani will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 45
All Time: 45
