How to Replace The Keypad.
The Keypads broken and i have a casing of Nokia 5310 XpressMusic
The keypad design for both the 5310 and 5310b is completely identical, so you can easily replace it using your 5310 casing.
Here is the step-by-step guide for the replacement:
Nokia 5310b XpressMusic Keypad Replacement(Note: As mentioned in Step 3 of the guide, some models require you to remove the screws from the back before lifting the faceplate, so please double-check your device first!)
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 55
All Time: 55
