Back cover is bulging out
Back cover bulging out. Is it a bad battery? Phone use is not effected.
Yes, that is almost certainly a bad battery. As batteries age, the chemical reactions that generate electricity start to break down and generate gasses instead. Those gasses cause the outer coating to swell, expanding the only direction possible, out the back of the phone. If you check your battery health, I suspect you'll find it's degraded, but regardless a swelling battery needs to be replaced immediately. This guide will tell you everything you need to know about a swollen battery.
What to do with a swollen battery - iFixit
Of course, instructions for replacing the battery would be helpful as well, and iFixit has you covered there, too.
Samsung Galaxy S24 Battery Replacement - iFixit Repair Guide
Battery is the first thing I would suspect before anything else. It's often the culprit. After a few years batteries start to wear down.
Be VERY careful. If it is the battery, it can explode. If you open the case, do it in a well ventilated area and keep it away from anything flammable.
Past 24 Hours: 0
Past 7 Days: 29
Past 30 Days: 29
All Time: 29
