Samsung Galaxy S24 Battery Replacement
  1. Samsung Galaxy S24 Battery Replacement, Prepare your phone for disassembly: step 1, image 1 of 2 Samsung Galaxy S24 Battery Replacement, Prepare your phone for disassembly: step 1, image 2 of 2
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium-ion battery may catch fire if damaged.
    • Completely power off your phone and unplug all cables.
  2. Samsung Galaxy S24 Battery Replacement, Heat the right edge: step 2, image 1 of 1
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
    • You can use also use a hair dryer or heat gun to heat the right edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
  3. Samsung Galaxy S24 Battery Replacement, Insert an opening pick: step 3, image 1 of 3 Samsung Galaxy S24 Battery Replacement, Insert an opening pick: step 3, image 2 of 3 Samsung Galaxy S24 Battery Replacement, Insert an opening pick: step 3, image 3 of 3
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble, apply more heat to further soften the adhesive.
    • Insert an opening pick into the gap.
  4. Samsung Galaxy S24 Battery Replacement, Separate the right adhesive: step 4, image 1 of 3 Samsung Galaxy S24 Battery Replacement, Separate the right adhesive: step 4, image 2 of 3 Samsung Galaxy S24 Battery Replacement, Separate the right adhesive: step 4, image 3 of 3
    • Slide your opening pick along the right edge between the back cover and the frame to slice through the adhesive.
    • Leave your opening pick in the bottom right corner to keep the adhesive from resealing.
  5. Samsung Galaxy S24 Battery Replacement, Heat the bottom edge: step 5, image 1 of 1
    • Reheat your iOpener and apply it to the bottom of the back cover for two minutes.
  6. Samsung Galaxy S24 Battery Replacement, Separate the corner adhesive: step 6, image 1 of 2 Samsung Galaxy S24 Battery Replacement, Separate the corner adhesive: step 6, image 2 of 2
    • Rotate the opening pick around the bottom right corner to separate the adhesive.
  7. Samsung Galaxy S24 Battery Replacement, Separate the bottom adhesive: step 7, image 1 of 2 Samsung Galaxy S24 Battery Replacement, Separate the bottom adhesive: step 7, image 2 of 2
    • Insert a second opening pick to the left of the first one and slide it along the bottom edge to slice through the adhesive.
    • Leave your opening pick in the bottom left edge to prevent the adhesive from resealing.
  8. Samsung Galaxy S24 Battery Replacement, Heat the left edge: step 8, image 1 of 1
    • Reheat your iOpener and apply it to the left side of the back cover for two minutes.
  9. Samsung Galaxy S24 Battery Replacement, Separate the corner adhesive: step 9, image 1 of 2 Samsung Galaxy S24 Battery Replacement, Separate the corner adhesive: step 9, image 2 of 2
    • Rotate the opening pick around the bottom left corner to separate the adhesive.
  10. Samsung Galaxy S24 Battery Replacement, Separate the left adhesive: step 10, image 1 of 2 Samsung Galaxy S24 Battery Replacement, Separate the left adhesive: step 10, image 2 of 2
    • Insert a third opening pick above the last one and slide it along the left edge to slice through the adhesive.
    • Only insert your pick up to 4 mm deep to avoid damaging the rear cameras or flash.
    • Leave your opening pick in the top left corner to prevent the adhesive from resealing.
  11. Samsung Galaxy S24 Battery Replacement, Heat the top edge: step 11, image 1 of 1
    • Reheat your iOpener and apply it to the top of the back cover for two minutes.
  12. Samsung Galaxy S24 Battery Replacement, Separate the corner adhesive: step 12, image 1 of 2 Samsung Galaxy S24 Battery Replacement, Separate the corner adhesive: step 12, image 2 of 2
    • Rotate the opening pick around the top left corner to separate the adhesive.
  13. Samsung Galaxy S24 Battery Replacement, Separate the top adhesive: step 13, image 1 of 3 Samsung Galaxy S24 Battery Replacement, Separate the top adhesive: step 13, image 2 of 3 Samsung Galaxy S24 Battery Replacement, Separate the top adhesive: step 13, image 3 of 3
    • Insert a fourth opening pick in the top left corner at the same depth and slide it along the top edge and around the top right corner to slice through the adhesive.
  14. Samsung Galaxy S24 Battery Replacement, Separate the flash adhesive: step 14, image 1 of 2 Samsung Galaxy S24 Battery Replacement, Separate the flash adhesive: step 14, image 2 of 2
    • Insert a fifth opening pick directly above the camera flash cutout.
    • Insert the opening pick under the top of the back cover until you feel it start to snag on the flash adhesive.
    • Insert the pick deeper into the phone until you feel the adhesive completely separate from the back cover.
    • Don't insert the pick any deeper than its center point to avoid damaging the rear cameras.
  15. Samsung Galaxy S24 Battery Replacement, Remove the back cover: step 15, image 1 of 2 Samsung Galaxy S24 Battery Replacement, Remove the back cover: step 15, image 2 of 2
    • Pick up the back cover by its edges and remove it from the phone.
    • If your cover is still sticking to the frame, slide the tip of an opening pick around the perimeter until the cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat and isopropyl alcohol (90% or greater) if you're having trouble removing the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  16. Samsung Galaxy S24 Battery Replacement, Disconnect the wireless charging coil: step 16, image 1 of 2 Samsung Galaxy S24 Battery Replacement, Disconnect the wireless charging coil: step 16, image 2 of 2
    • Use the point of your spudger to pry up and disconnect the wireless charging coil press connector from the motherboard.
    • To re-attach press connectors, align the connector carefully over its socket and press down with your fingertip—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  17. Samsung Galaxy S24 Battery Replacement, Remove the wireless charging coil and loudspeaker screws: step 17, image 1 of 3 Samsung Galaxy S24 Battery Replacement, Remove the wireless charging coil and loudspeaker screws: step 17, image 2 of 3 Samsung Galaxy S24 Battery Replacement, Remove the wireless charging coil and loudspeaker screws: step 17, image 3 of 3
    • Use a Phillips screwdriver to remove the thirteen 3.5 mm‑long screws securing the wireless charging coil and the loudspeaker:
    • Six screws securing the wireless charging coil
    • Seven screws securing the loudspeaker
  18. Samsung Galaxy S24 Battery Replacement, Remove the wireless charging coil and loudspeaker: step 18, image 1 of 2 Samsung Galaxy S24 Battery Replacement, Remove the wireless charging coil and loudspeaker: step 18, image 2 of 2
    • Insert the point of a spudger in the notch located on the left edge of the loudspeaker assembly.
    • Pry up the loudspeaker to release its clips.
  19. Samsung Galaxy S24 Battery Replacement: step 19, image 1 of 3 Samsung Galaxy S24 Battery Replacement: step 19, image 2 of 3 Samsung Galaxy S24 Battery Replacement: step 19, image 3 of 3
    • Use your fingernail or the flat end of a spudger to pry up the wireless charging coil and loudspeaker assembly away from the frame.
    • Remove the wireless charging coil and loudspeaker from your phone.
    • During reassembly, press around the edges of the loudspeaker to clip it to the frame before reinserting the screws.
  20. Samsung Galaxy S24 Battery Replacement, Disconnect the battery: step 20, image 1 of 2 Samsung Galaxy S24 Battery Replacement, Disconnect the battery: step 20, image 2 of 2
    • Insert the flat end of a spudger under the battery cable press connector (located on the motherboard) and pry up to disconnect it.
  21. Samsung Galaxy S24 Battery Replacement, Disconnect the interconnect cables: step 21, image 1 of 3 Samsung Galaxy S24 Battery Replacement, Disconnect the interconnect cables: step 21, image 2 of 3 Samsung Galaxy S24 Battery Replacement, Disconnect the interconnect cables: step 21, image 3 of 3
    • Insert the point of a spudger under the secondary interconnect cable press connector labeled "MAIN" (located on the bottom right corner of the motherboard) and pry up to disconnect it.
    • Repeat this process for the primary interconnect cable connector.
  22. Samsung Galaxy S24 Battery Replacement: step 22, image 1 of 2 Samsung Galaxy S24 Battery Replacement: step 22, image 2 of 2
    • Repeat this process to disconnect the display and 5G mmWave cable press connectors located on the bottom left edge of the motherboard.
  23. Samsung Galaxy S24 Battery Replacement: step 23, image 1 of 3 Samsung Galaxy S24 Battery Replacement: step 23, image 2 of 3 Samsung Galaxy S24 Battery Replacement: step 23, image 3 of 3
    • Repeat this process to disconnect the two interconnect cable press connectors located on the daughterboard, and the display cable connector to the left of the daughterboard.
  24. Samsung Galaxy S24 Battery Replacement, Remove the interconnect cables: step 24, image 1 of 3 Samsung Galaxy S24 Battery Replacement, Remove the interconnect cables: step 24, image 2 of 3 Samsung Galaxy S24 Battery Replacement, Remove the interconnect cables: step 24, image 3 of 3
    • Remove the two interconnect cables and the display cable from your phone.
  25. Samsung Galaxy S24 Battery Replacement, Move the cables: step 25, image 1 of 2 Samsung Galaxy S24 Battery Replacement, Move the cables: step 25, image 2 of 2
    • Gently bend the 5G mmWave antenna and battery cables so they are pointing straight up.
  26. Samsung Galaxy S24 Battery Replacement, Separate the battery pull tab: step 26, image 1 of 3 Samsung Galaxy S24 Battery Replacement, Separate the battery pull tab: step 26, image 2 of 3 Samsung Galaxy S24 Battery Replacement, Separate the battery pull tab: step 26, image 3 of 3
    • Be very careful not to bend, crease, or puncture the battery during the next few steps. A damaged battery can leak dangerous chemicals and catch fire.
    • Peel the battery pull tab away from the battery, towards the left edge of the phone.
    • If you're having trouble getting the pull tab up, use an opening pick or other thin plastic tool at a low angle to peel up a corner before using your fingers. Never use a metal tool or press into the battery.
  27. Samsung Galaxy S24 Battery Replacement: step 27, image 1 of 3 Samsung Galaxy S24 Battery Replacement: step 27, image 2 of 3 Samsung Galaxy S24 Battery Replacement: step 27, image 3 of 3
    • Separate the small, clear tabs above and below the blue part of the pull tab from the rest of the pull tab.
    • Your device may have two additional tabs on the bottom edge of the battery. These are designed to tear away during the next step, but if you have trouble removing the battery, you can carefully peel these tabs up as well.
    • Bend these small tabs away from the battery to make sure they stay clear of the battery.
    • If these tabs aren't separated, you won't be able to lift the battery in the next step. You can tape these tabs to the side of the phone or the screen to keep them out of the way.
  28. Samsung Galaxy S24 Battery Replacement, Remove the battery: step 28, image 1 of 2 Samsung Galaxy S24 Battery Replacement, Remove the battery: step 28, image 2 of 2
    • When you pull out the battery, its left edge will come up, but the right edge will not. You'll remove the remaining film and the battery in the next step.
    • Firmly hold the phone in place and grip the blue center pull tab.
    • Pull straight up to separate the battery adhesive using firm, steady force.
    • If you're having trouble, apply 1-2 drops of high-concentration (more than 90%) isopropyl alcohol to the left edge of the battery. Lift the left edge of your phone and wait one minute for the alcohol to soften the adhesive.
    • Lift the battery until it is perpendicular to the phone and hold/rest it in the right edge of the frame.
  29. Samsung Galaxy S24 Battery Replacement: step 29, image 1 of 3 Samsung Galaxy S24 Battery Replacement: step 29, image 2 of 3 Samsung Galaxy S24 Battery Replacement: step 29, image 3 of 3
    • Use your fingers to peel the adhesive film from the frame.
    • Remove the battery and its film.
    • If you used isopropyl alcohol, wait ten minutes before installing the new battery to allow the alcohol to completely evaporate.
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
Calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy S24 Answers Community for troubleshooting help.
2 other people completed this guide.
Nick Schultz
53,482 Reputation
305 Guides authored
iFixit Member of iFixit
Staff
123 Members
25,683 Guides authored
3 Guide Comments
Very detailed instruction, thank you!
What glue to be used to put the cover back?
Vladimir Skublin - Reply Share
We have custom cut Galaxy S24 rear cover adhesive on our store, which will work perfectly. It's also included in the Fix Kit, which includes everything you'll need. Happy repairing!
Nick Schultz - Reply Share
Nice informative tutorial. However, in hopes of helping others reading this, I did NOT have a heat source, but instead grabbed the suction cup thingy out of the toolkit and going around the corners on the back of the android phone about 10 times, one of the corners popped up/off and I used the guitar pic to cut through the glue around the rest of the phone backing, I did lose some coloring where the black plastic was still stuck to some of the glue, but no one sees it with a cover over it anyway, and the best part, this trick worked for the really desperate user. My phone will only charge when it is truly at 0%, I am going to try to buy a new battery with the proper size/serial# in hopes for a cheaper fix than phone replacement because, 1) the knockoff Chine phone I bought 6 weeks ago on Amazon had a battery that actually had a corner tear or weird look to it, and 2) the charger they sent was bulging outward in a weird undesirable way that may have caused battery damage. Wishing you and me luck!!!
Jonathan Esker - Reply Share
Past 24 Hours: 60
Past 7 Days: 435
Past 30 Days: 1,736
All Time: 19,878
