Repair and support for the controllers that shipped with the PS3. Released in November 2007 (Japan only) and 2008 (other countries), the six-axis lithium battery powered controller (CECHZC2) is straightforward to repair.
My controller stopped working without any fall or strain.
I'm having a problem with my PS3 controller. I was playing GTA V when the screen suddenly went black, so I turned off my PS3 by pressing and holding the power button for about 10 seconds. After that, I turned the console back on, and it worked perfectly and went to the main menu without any problems. However, the controller has completely stopped working. Even though it was charged beforehand, it's completely unresponsive. I tried connecting it to the console via USB cable, but it didn't work. I also tried connecting it to the charger, but there's no charging light or any indicator light. When I press the PS button, no light comes on at all, and there's no flashing or response. It seems like the problem is with the controller itself, not the PS3 console. What are the possible causes of this malfunction? Are there any diagnostic or repair steps I can try?
Add a comment
1 Answer
Most Helpful Answer
Hi!
Most of the time motherboard related.
I would replace the battery first > DualShock 3 Battery Replacement and see if that helps.
If not, it's most likely motherboard related. Check for shorts on the motherboard.
Otherwise, get a new controller. A new motherboard would not be easy to find, and if you can find one, it's probably just as expensive..
Score 1
Add a comment
Add your answer
Kamel Benmaati will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 35
