Up to 20% off select tools
DualShock 3 Battery Replacement
Views: 242K
View statistics:
Past 24 Hours:
75
Past 7 Days:
383
Past 30 Days:
1,576
All Time:
241,621
Comments: 44
24 comments on steps, 20 guide comments.
Go to guide comments
Completed: 172
172 people have marked this guide "completed." Will you be next?
Favorites: 101
101 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the internal lithium battery inside PlayStation 3 controllers.
    1. DualShock 3 Battery Replacement, Rear Cover: step 1, image 1 of 1
      • Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
      Ask FixBot
    2. DualShock 3 Battery Replacement: step 2, image 1 of 1
      • Press on the rear cover between the analog sticks and slightly lift the lower edge of it away from the rest of the controller.
      Ask FixBot
    3. DualShock 3 Battery Replacement: step 3, image 1 of 2 DualShock 3 Battery Replacement: step 3, image 2 of 2
      • Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
      • Pull the rear cover away from the rest of the controller, being careful not to pop off the #2 triggers.
      • If you happen to accidentally pop off the trigger buttons, we have a trigger button guide to reattach them.
      Ask FixBot
    1. DualShock 3 Battery Replacement, Battery: step 4, image 1 of 1
      • Lift the battery off the motherboard for enough clearance to access the battery connector.
      Ask FixBot
    2. DualShock 3 Battery Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Carefully pull the battery connector away from its socket on the motherboard.
      • It may be helpful to use a pair of tweezers or pliers to grab the battery connector when you disconnect it for the first time. Only pull on the connector. Do not try to remove by pulling on the red and black wires.
      Ask FixBot
172 other people completed this guide.
Author
with
20 Guide Comments
I got the shell separated but unfortunately snapped the lil plastic clip on the rear of the controller's bottom half. a lil super glue and treezers fixed tht up nicely...Thanks for the help
KUDOS to you!!!
Rob (rjmat42)
Robert - Reply Share
I have different battery on my second controller, battery itself have pins to connect it with board, no more white plastic holder :/
Raf - Reply Share
Try Amazon Cody
linzikerner - Reply Share
whats is amazon cody?
Albert Einstein - Reply Share
Anyone have any idea where I can find the plastic retainers for the battery? I bought the new one, but my old battery has the clips attached. I don't want this thing just jiggling around in there, it'll drive me nuts.
Thanks.
geoquin4 - Reply Share
Past 24 Hours: 75
Past 7 Days: 383
Past 30 Days: 1,576
All Time: 241,621
