Up to 20% off select tools
PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
when unplug cable controller shutdown
after the light blue and seen in ps4 and unplug the controller disconnecting and shutdown
battery new
cable for charging board new
charging board new
everything new but the Bluetooth not working when i click share with ps
thanks from Syria
Score 1
Add a comment
1 Answer
Most Helpful Answer
Hi!
So, you have replaced the battery and the issue is still not fixed?
Usually this is caused by the battery. It's possible that the replacement part is faulty. Where did you bought the battery? Maybe it's better to try another seller and get another battery just to be sure.
If that also fails, then most likely it's motherboard related... But before diving in there, I would try another battery and see what happens.
Score 1
Add a comment
Add your answer
Mustafa Dahrouj will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 98
