Repair, disassembly, and troubleshooting information for the iPhone 15, released September 22nd, 2023. It features a 6.1" OLED display, a 48 MP dual-camera system, and USB-C.
My torch is not working
My torch is not working it will come on but very light if I move the brightness up and down
Score 1
Add a comment
1 Answer
If the flashlight turns on but is very dim regardless of the brightness slider, it could be caused by a failing flash module, a camera-related issue, low battery, or a hardware fault.
If it's an iPhone, check whether the camera is also behaving normally. If you're seeing other symptoms like restarts or performance issues, run an iPhone panic log analysis to check for hardware-related errors. If it's an Android device, generate a bug report and run an online bug-report (crash) analysis to look for camera or system-related faults.
Add a comment
Add your answer
Benigno Dias will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 39
All Time: 101
