My laptop is not charging
Thanks for getting back to me
And i will try that but there is another issue came
I was sucking in the air from both the port of charger and the laptops charging port
As i thought there would be some debris in it
Then i pluged in and it worked but the light started flickering and then it didnt charge
I thought it would be moisture and left it there after some like 2 hr the charger started to work again i used it on a mobile but the laptop wasnt charging i powered the laptop and it was working fine that means the motherboard it fine but it is not charging
So if you can help i would be grateful and sorry for the english if it dosent make sense
1 Comment:
Hi @saifullahr85935
You said in your first question that "...i pluged in my charger to other laptops and it was the same problem but there chargers were doing fine", did you mean that other known working chargers (not yours) did charge the battery in your laptop, presumably with no problems?
If they did, it still points to your charger being the problem
by
Add a comment
