Repair guides, disassembly, and troubleshooting information for the 14-inch MacBook Pro with the M4 Pro or M4 Max chip, released in October 2024.
The hinge tight problem in my MacBook Pro
recently purchased a MacBook Pro m4, on the first day I was able to open my laptop lid using one finger. from second day onwards I was not able to open the lid with one finger. the hinges become tight when I used to open with one finger the base also come along with the lid. the one finger supremacy has gone. what will be the solution.
1 Comment
If you have a 16" model here's the guides for it 16" MacBook Pro
by
Add a comment
1 Answer
Chosen Solution
You may want to see if the seller is able to fix your system under warranty as it could be a misaligned hinge.
If that's not practical and you are sure it's not an alignment issue get a can of WD40 lubricant and a small container to spray into to create a puddle of the spay (only need a very little!) then dipping a cotton swab just enough to dampen as we don't need much, wipe the hinge where the two half's meet. Don't over do it as it really only takes a little. Lift and lower the display a few times and then wipe off any excess lube.
Score 1
1 Comment:
Sure. let me see, I am taking my lap to Apple Store today, if they refuse I will do as you said. Thank you.
by
Add a comment
Add your answer
Nihad will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 85
All Time: 228
