Psp e1004 (Street) backlight not working.
Hi, I have a PSP e1004 (Street model). I'm having a problem with the backlight. The display works fine with a flashlight, but the backlight isn't working properly. I replaced the backlight circuit fuse, but the problem remains the same: the backlight isn't working. What could be the cause?
I checked the soldered fuse with a multimeter, and it was soldered correctly.
2 Comments
Hi!
How are the traces near the fuse? All look good?
Also, did you tried another screen? It could be the backlight in the screen itself.
Thanks!
by koppie007
@dan0 I replaced the fuse, and after checking the entire board, I noticed a single pin on the flat connector port was displaced and touching another pin. I fixed it with a small needle and a microscope, and now the backlight is working properly again.
by Alex Mari
