Up to 20% off select tools
PSP E1000 Screen black
Views: 2.6K
View statistics:
Past 24 Hours:
6
Past 7 Days:
44
Past 30 Days:
255
All Time:
2,589
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
How to fix your pspe with not working screen (black screen backlight not working)
    1. PSP E1000 Screen black, PSP E1000 Screen black: step 1, image 1 of 1
      • This is the front and back of the PSP E1000
      Ask FixBot
    2. PSP E1000 Screen black: step 2, image 1 of 2 PSP E1000 Screen black: step 2, image 2 of 2
      • Remove all four screws on the back using the same bit as before.
      • Then remove the two top screws.
      Ask FixBot
    3. PSP E1000 Screen black: step 3, image 1 of 1
      • Insert wisdom here.Gently unclip the display ribbon cable and remove it Then set the display to the side Untape the front panel ribbon cable, unclip it, then remove it.
      Ask FixBot
    4. PSP E1000 Screen black: step 4, image 1 of 1
      • Remove the ribbon cable and power cable Gently lift the button assembly and charge port The shoulder button is taped down so slide a spudger under the button and gently peel it off
      Ask FixBot
    5. PSP E1000 Screen black: step 5, image 1 of 1
      • Unclip and remove the two marked ribbon cables Remove the marked screw and lift the analog stick out Lift the button pad carefully and peel off the shoulder button When reassembling install the joystick before the buttons.
      Ask FixBot
    6. PSP E1000 Screen black: step 6, image 1 of 1
      • Unclip both ribbon cables and remove them Remove the marked screw on the mainboard Lift the bottom of the mainboard up and slide it out For reinstallation make sure that the power switch cover is installed before it is screwed in. It has to be unscrewed to do the installation
      Ask FixBot
    7. PSP E1000 Screen black: step 7, image 1 of 1
      • Congratulations you have disassembled your PSP E1000. Have fun with the reassembly!
      Ask FixBot
    8. PSP E1000 Screen black: step 8, image 1 of 1
      • disassemble the console, take a multimeter and measure whether the fuse conducts current, if not, remove the fuse with scissors from a 3D printer or pliers and connect the 2 elements together
      Ask FixBot
    9. PSP E1000 Screen black: step 9, image 1 of 1
      • here is the fuse
      Ask FixBot
Author
with
Błażej Stosio
209 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 44
Past 30 Days: 255
All Time: 2,589
