Repair guides, disassembly, and troubleshooting information for the 5th-generation Apple iPad with Wi-Fi, available with 32 or 128 GB of storage. Released in March 2017. Identified by model number A1822. Features a 9.7" Retina display and 64-bit A9 processor.
Ipad doesnt charge when its turned on.
I have an Ipad 5th gen that charges normally when turned off. The moment it boots the Amps drop to 0. There's no debris and nothing is stuck in the charging port.
if its turned on the battery also doesn't go higher than 1%
Add a comment
1 Answer
Most Helpful Answer
Hi @schormn
The battery may need replacing.
Here's the ifixit iPad 5 Wi-Fi Battery Replacement guide that shows what to do.
Score 2
3 Comments:
hi, so i replaced the battery but i'm still having the same issue. do you think it might be a chip problem om the logic-board?
by
@schormn
Don't know Apple products that well but in the tablet go to Settings > Privacy & Security > Analytics & Improvements > Analytics Data and see if there's a panic log which may have data in it that may show what's happening.
If there is post it back here in your question above (click on Options > Edit) and maybe one of the other regular contributors more versed with Apple may be able to spot something.
by
hi, Ive figured out it was a chip on the logicboard. thanks for the help though!!
by
Add a comment
Add your answer
James will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 47
